2 Pages<12
#11 Posted : Sunday, December 15, 2013 1:23:08 AM(UTC)
Well I am stumped.
I cannot think of anything that would cause the defrost relay to stutter.
Try forcing a defrost cycle to see if it will actually do a defrost.
Check the defrost thermostat. If it is deformed/bulged replace it.
Check across the control thermostat.
You should have 0 volts across it when the unit is on.
mansoura
#12 Posted : Sunday, December 15, 2013 11:16:24 AM(UTC)
mansoura
How exactly would I do this? Noob question, I'm sure.
mansoura
#13 Posted : Sunday, December 15, 2013 6:13:59 PM(UTC)
mansoura
Just to be sure, the control thermostat and defrost thermostat are the same thing correct? The voltage across what I know to be the defrost thermostat is indeed 0 V when the unit is on.
mansoura
#14 Posted : Sunday, December 15, 2013 6:32:10 PM(UTC)
mansoura
Ok I figured out what the control thermostat was. I tried to test the voltage across the two terminals and the whole thing went up in sparks! Needless to say the relay is fried. I have no idea why this happened. Could this be the reason it is messed up? It's obviously messed up now. Here's a pic:
mansoura attached the following image(s):
#15 Posted : Sunday, December 15, 2013 11:44:55 PM(UTC)
Yes it could be the cause of your problems.
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 3/22/2016 6:52:44 AM(UTC)
Frigidaire Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by wing471 9/7/2015 5:42:56 AM(UTC)
Freezer cold but not freezing, refrigerator not cold enough (Refrigerator & Freezer Repair)
by tyltea1st@charter.net 6/5/2014 6:06:36 AM(UTC)
Freezer & Refrigerator not cold enough (Refrigerator & Freezer Repair)
by HFrank 5/30/2013 10:53:56 AM(UTC)
Freezer and Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by mahplane 8/29/2012 9:11:03 PM(UTC)
by tonlam 11/30/2011 7:02:14 AM(UTC)
Magic Chef Refrigerator Freezer work Refrigerator not cold enough (Refrigerator & Freezer Repair)
by tg06222 9/3/2011 3:28:36 PM(UTC)
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 7/25/2011 6:11:51 PM(UTC)
Kenmore refrigerator not cold enough (Refrigerator & Freezer Repair)
by Malinda 5/14/2011 7:00:23 AM(UTC)
by teresa in mo 4/25/2011 5:33:30 AM(UTC)
by davidwaynesmith 4/8/2011 5:16:07 AM(UTC)
Freezer and Refrigerator not cold enough (Refrigerator & Freezer Repair)
by fionmay 1/22/2011 10:57:42 AM(UTC)
Side by side refrigerator not cold enough (Refrigerator & Freezer Repair)
by Bhedman 1/8/2011 7:32:16 AM(UTC)
Frigidaire side by side refrigerator freezer working refrigerator not cold enough (Refrigerator & Freezer Repair)
by SSOWDERS 9/15/2009 6:15:20 PM(UTC)
by mfd 10/29/2007 9:47:56 AM(UTC)
2 Pages<12
