larrycooper
#1 Posted : Thursday, December 12, 2013 9:14:05 AM(UTC)
larrycooper
Broiler doesn't ignite - Igniter glows red but no gas. Oven and stovetop burners work fine.
masterquinn
#2 Posted : Thursday, December 12, 2013 10:25:51 AM(UTC)
masterquinn
sounds like your ignitor is too weak. here is the method for testing the ignitor :
Disconnect or remove igniter and measure its resistance. Cold resistance should be between 50 and 150 Ohms. (The value of the resistance is not important as long as the igniter is not open or shorted).
Fiction: Testing for a good igniter is done by measuring its Resistance (Ohms).
Fact: The test of an igniter is done by measuring the current draw (amps) of the ignition circuit.
Using wrap-around amp. meter - test one leg for amp. draw.
1) NORTON (flat) Igniter - 3.2 to 3.6 amps.
2) CARBORUNDUM (round) Igniter - 2.5 to 3.0 amps.
If amp. draw NOT within proper range - replace the igniter.
If correct amp. draw is present - replace valve.
larrycooper
#3 Posted : Thursday, December 12, 2013 5:31:19 PM(UTC)
larrycooper
Thanks, great info
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Non of the oven or broiler work (Oven Repair (including Ranges and Cooktops))
by Guest 12/12/2023 3:15:56 PM(UTC)
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Tappan oven or broiler won't ignite (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2023 6:57:29 AM(UTC)
Oven Broiler Always on High (Oven Repair (including Ranges and Cooktops))
by tolinrome 10/7/2023 12:17:48 PM(UTC)
oven / broiler control backwards? (Oven Repair (including Ranges and Cooktops))
by DulceDP 1/31/2023 10:34:07 AM(UTC)
JennAir prg3010np broiler troubleshooting (Oven Repair (including Ranges and Cooktops))
by TJQuill 1/25/2023 8:39:17 PM(UTC)
KitchenAid double oven - broiler working, oven won't warm (Oven Repair (including Ranges and Cooktops))
by jcz24 11/28/2022 5:53:17 AM(UTC)
Electric Broiler element meltdown (Oven Repair (including Ranges and Cooktops))
by lilsad 7/24/2022 9:59:00 AM(UTC)
Broiler igniter issue (Oven Repair (including Ranges and Cooktops))
by Nubthumb 7/20/2022 4:36:27 PM(UTC)
Thor oven and broiler not lighting (Oven Repair (including Ranges and Cooktops))
by dungears 6/8/2022 2:05:55 PM(UTC)
Viking Wall Oven (VGS 0165) Infrared Broilers Help (Oven Repair (including Ranges and Cooktops))
by emstone 12/31/2021 10:01:42 AM(UTC)
Using a Broiler element to replace a bad Bake Element (Oven Repair (including Ranges and Cooktops))
by Guest 11/22/2021 2:49:19 PM(UTC)
Jenn-Air Broiler (JES9800CAB01) (Oven Repair (including Ranges and Cooktops))
by BCT 11/1/2021 9:02:00 PM(UTC)
