My broiler quit a while back (couple of years). I replaced the EOC and the igniter. Didn’t fix the problem and I figured it was because I went cheap with the igniter. Started getting a F30 code. Temp probe resistance was correct so I ordered a EOC and got a good igniter while I was at it. Still not working. I’m not sure when power goes to the igniter, but I’m not getting a reading when I hit the button. The new one ohms out at 119 (the cheap one was 93). The schematic shows one of the leads coming from the dual valve but the bake side works fine. Any ideas? Thanks
