emstone
#1 Posted : Friday, December 31, 2021 10:01:42 AM(UTC)
emstone
Greetings All,
Unfortunately, we have no companies that service Viking near me. We moved into this house with a circa 1990's Viking double oven range.
I just finished replacing all the ignitors but the infrared broilers on both the top and bottom aren't working. After 60 seconds or so, I can smell a faint gas smell but never ignition.
I'm lost on the next step.
If it helps, here is the parts diagram: https://allvikingparts.c...wnloadables/VGSO165.pdf.
Also, if it's important, the house is on LP not NG. I assume the thing was converted correctly at install.
Thanks in advance.
