Tom Clardy
#1 Posted : Monday, November 25, 2013 9:36:31 AM(UTC)
Tom Clardy
The dual element on my stove will turn on fully but will not turn off and on to maintain the desired temp. It stays on full heat no mater what temp setting that I turn the dial for.
I replaced the elemen and i replaced the switch.
Can this be caused by anything else?
If i made a mistake with the wire replacement--could this cause the problem?
Thanks.
#2 Posted : Tuesday, November 26, 2013 2:49:18 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Frigidaire FES367CESB Range - AppliancePartsPros.com
Here is a better wiring diagram that also includes a wiring layout.
It is the closest I could find to a CESB unit.
It is for a CESC.
The only difference I can see is the placement of the Hot Surface light.
The circuit is the same they just place it to left of the limiter instead of the right.
CESB is L2 , LIMITER , HOT SURFACE light , L1
CESC is L2 , HOT SURFACE light , LIMITER , L1
Yes mis-wiring can cause your problem.
The wiring layout may help you figure out the proper wiring.
Electric range elements won't heat (Oven Repair (including Ranges and Cooktops))
by danaitken1 10/20/2016 8:48:32 AM(UTC)
replacing range element with lower wattage (Oven Repair (including Ranges and Cooktops))
by qwickpix 9/27/2013 2:13:58 PM(UTC)
Range element keeps getting hot (Oven Repair (including Ranges and Cooktops))
by gschvach 10/13/2012 12:18:56 PM(UTC)
Range Element Operates Sporadically (Oven Repair (including Ranges and Cooktops))
by mislff 3/29/2012 1:47:54 PM(UTC)
Whirlpool glass top range elements cycle on and off (Oven Repair (including Ranges and Cooktops))
by lca2faraway 3/27/2012 7:53:23 AM(UTC)
range elements won't stay hot cycle on and off (Oven Repair (including Ranges and Cooktops))
by lca2faraway 3/26/2012 8:11:44 AM(UTC)
Maytag Range Element quit working (Oven Repair (including Ranges and Cooktops))
by TheKaister 8/30/2010 5:36:39 PM(UTC)
Frigidaire CFEF366EM range element doesnt work properly (Oven Repair (including Ranges and Cooktops))
by bini_182001 3/22/2010 8:03:50 AM(UTC)
replace range element (Oven Repair (including Ranges and Cooktops))
by davidhutch 8/25/2009 4:44:19 AM(UTC)
How to remove range element from top (Oven Repair (including Ranges and Cooktops))
by dieselgg 6/30/2009 3:12:33 PM(UTC)
One range element not heating after oil fire (Oven Repair (including Ranges and Cooktops))
by Rich777 6/15/2009 10:47:24 AM(UTC)
Range Element Stand-offs (Oven Repair (including Ranges and Cooktops))
by Pikaki's Dad 2/9/2009 5:15:30 PM(UTC)
Maytag Range Element Failure (Oven Repair (including Ranges and Cooktops))
by dawiz 5/14/2008 5:49:12 PM(UTC)
