breezer4
#1 Posted : Wednesday, November 13, 2013 9:06:16 AM(UTC)
breezer4
My microwave run constantly when plugged in with door open or closed. What is the likely cause and can the possible defective part(s) be tested?
Scott
breezer4
#2 Posted : Wednesday, November 13, 2013 9:08:22 AM(UTC)
breezer4
Scott
Microwave runs constantly when plugged in with door open or closed.
Appliance Ninja
#3 Posted : Wednesday, November 13, 2013 9:57:49 AM(UTC)
Appliance Ninja
You likely have a faulty door switch. It is just the fan running, correct? The unit is not actually heating, is it?
breezer4
#4 Posted : Wednesday, November 13, 2013 11:14:13 AM(UTC)
breezer4
Uncertain if unit is heating or not. Will have to check that aspect. Unit has 3 door switches. How would I know which one(s) might be defective?
Appliance Ninja
#5 Posted : Wednesday, November 13, 2013 11:20:46 AM(UTC)
Appliance Ninja
It will be the top or the bottom one, the middle is not suspect. You can test them for continuity or replace them both, they are not expensive and are available below. They are the same switch, so you would need to order two.
GE WB24X829 Door Sensing Switch - AppliancePartsPros.com
breezer4
#6 Posted : Wednesday, November 13, 2013 5:19:32 PM(UTC)
breezer4
Ninja,
Thank you for your response. I will meter both the top and bottom out of curiosity but intend to replace both per your suggestion. Much cheaper than a new microwave purchase and I have it apart now anyhow.
Scott
Appliance Ninja
#7 Posted : Wednesday, November 13, 2013 5:21:30 PM(UTC)
Appliance Ninja
Let me know how the repair goes, thanks!
Guest (8)
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
