My surface indicator light will not go off
Originally Posted by: Kpsanders55@sbcglobal.net  My surface indicator light will not go off My stovetop indicator light will not go off
Here are your parts Parts for RF212PXSQ - AppliancePartsPros.comYou are missing the last digit of your model number so will have to choose the correct one from the Matching Model Numbers section. You probably have a bad infinite switch. I think it is the violet wire that goes to the P lug on the switches. I may be able to confirm this if you give the last digit or the model number. Unplug the unit and then one of the wires (violet) or plugs making sure that nothing can short out. Then plug the unit in. Do one at the time till you find the bad switch. |
THIS FORUM IS DEAD!!!!!!! |
