2 Pages<12
jrnutpaul
#11 Posted : Monday, September 23, 2013 9:51:09 AM(UTC)
jrnutpaul
The coil reads as it did when I first checked it 12.3
jrnutpaul
#12 Posted : Monday, September 23, 2013 9:55:23 AM(UTC)
jrnutpaul
Oh...No short indicated from coil
jrnutpaul
#13 Posted : Monday, September 23, 2013 10:28:21 AM(UTC)
jrnutpaul
I just reread all the post in this thread....When I check the thermister I get an infinity read...you indicated it should read 10,000 ohms. Could this be why it overheats now that I've replaced the burnt wire? Do I need a new thermister?
jrnutpaul
#14 Posted : Monday, September 23, 2013 11:48:34 AM(UTC)
jrnutpaul
Opps...I screwed up. Moving the tester to 20k on the ohm scale I got a reading of 5.84 so, yes 10,000 ohms resistance. So, everything checks out good to go. It just overheats
#15 Posted : Tuesday, September 24, 2013 1:22:23 AM(UTC)
Is it too hot on all temperature settings?
You could check your exhaust temperatures, see page 9-5 in the manual.
Could be that the board is not controlling the temperature and it is being controlled by one of the high limit thermostats.
The thermostat will fail eventually as it's contacts are not made to continually turn the heater on/off.
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 10/8/2011 4:12:13 PM(UTC)
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 5/16/2011 8:58:46 AM(UTC)
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 4/6/2011 6:53:41 AM(UTC)
Help...my dryer stopped heating (Dryer Repair)
by BDGD 12/3/2010 12:47:30 PM(UTC)
by Tcon 10/17/2010 6:22:21 AM(UTC)
by jstayoung1 6/10/2010 12:37:53 AM(UTC)
by jstayoung1 6/10/2010 12:21:32 AM(UTC)
by atciskanik 3/3/2010 4:32:59 AM(UTC)
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 1/18/2010 5:39:07 AM(UTC)
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 9/5/2009 7:33:29 AM(UTC)
GE Elec stackable dryer stopped heating (Dryer Repair)
by arbiggs 4/21/2009 11:23:47 AM(UTC)
2 Pages<12
