I have an Amana side by side with ice and water through the door. My ice maker is not making ice. It makes the noise like the water is flowing but when I check there is no water in the ice tray. The water through the door is flowing fine, everything is frozen the way it should be but I have no ice. Please help!!!
The first thing I would check are the water tubes on the back of the fridge.
I had the same problem, manual said to clean out water valve brass filter. WATCH if you take it apart as mine has 2 springs that went when I opened it, now I am not sure how it goes back together It was not hard I just have to figure out how it goes back together Good luck Jaye
