Mikebl5
#1 Posted : Friday, August 23, 2013 1:56:58 PM(UTC)
Mikebl5
Light works but nothing runs..checked the Run Capacitor and that was not it.
What should I check next?
#2 Posted : Saturday, August 24, 2013 2:37:03 AM(UTC)
Parts for GE TBX22ZIZBRWW Refrigerator - AppliancePartsPros.com
Could be that you are stuck in a defrost cycle. It turns the compressor and fans off.
Try turning the defrost timer cam (item 648 in the Compartment Separator section).
It will only turn in one direction.
If the unit fires up then I would replace the timer.
Mikebl5
#3 Posted : Sunday, August 25, 2013 12:16:08 PM(UTC)
Mikebl5
Danman, I turned the defrost control and still nothing...what next do you think?
#4 Posted : Monday, August 26, 2013 2:31:57 AM(UTC)
I would check the main control thermostat (Item 300 in the Compartment separator)
Unplug the unit and measure across it's connectors. Should be 0 ohms.
It is a good idea to disconnect one side of the thermostat, this prevents you from reading an alternate/parallel circuit path.
Fridge stopped working (Refrigerator & Freezer Repair)
by SaskGuy 8/4/2014 3:38:54 PM(UTC)
Fridge stopped working.Cntl pnl lit as "-" (Refrigerator & Freezer Repair)
by Jerry Conice 7/31/2014 12:41:01 AM(UTC)
GE GSL25JFPABS Frezer/Fridge Stopped working (Refrigerator & Freezer Repair)
by mrs9693nj 3/26/2013 6:57:50 AM(UTC)
Ice maker Hotpoint Fridge stopped working (Refrigerator & Freezer Repair)
by djgolf 10/31/2010 12:40:33 PM(UTC)
Maytag Fridge Stopped Working (Refrigerator & Freezer Repair)
by dkrobinson 1/13/2010 9:23:03 PM(UTC)
