SDoe
#1 Posted : Saturday, July 27, 2013 2:18:48 PM(UTC)
SDoe
I just replaced the lid switch assembly, tested it and it worked. Screwed the control panel in and turned on the washer and the fuse blew. What would cause this? Is it possible that I switched the wires around? How can I find out which plug the white wire goes on and which plug the black wire goes on? Thanks for any help.
fairbank56
#2 Posted : Saturday, July 27, 2013 3:03:16 PM(UTC)
fairbank56
Groups: Expert
The white/green wire goes to 30 on the white check switch, black goes to M on same switch. If you had them switched, it would blow the fuse as soon as you turned the washer on with lid closed.
Eric
SDoe
#3 Posted : Saturday, July 27, 2013 3:32:18 PM(UTC)
SDoe
Thanks Eric. I had them switched. Could I have damaged the switch as well as the fuse? Or should correcting the wires and changing the fuse correct the problem?
fairbank56
#4 Posted : Saturday, July 27, 2013 3:41:40 PM(UTC)
fairbank56
Groups: Expert
The switch should be fine.
Eric
Blown fuse or shorted wires (Washer Repair)
by Indymom 7/26/2019 12:32:09 PM(UTC)
Blown Fuse (Dishwasher Repair)
by bicast 8/12/2013 11:53:47 PM(UTC)
Blown Fuse (Microwave Repair)
by Patrick Kennealy 7/2/2013 5:53:15 AM(UTC)
General Electric WPRE6100G0WT Washer blown fuse (Washer Repair)
by donhans 9/14/2012 2:55:27 PM(UTC)
kenmore elite blown fuse (Dishwasher Repair)
by smartyy 3/14/2012 4:20:29 PM(UTC)
Replaced Blown Fuse Still not working (Microwave Repair)
by Carms 12/29/2011 6:01:40 PM(UTC)
Blown fuse on LG refrigerator circuit board (Refrigerator & Freezer Repair)
by Longhorn20 2/21/2010 1:19:39 PM(UTC)
Oven Blown Fuse? (Oven Repair (including Ranges and Cooktops))
by steffco1 7/8/2008 4:07:51 PM(UTC)
Kenmore blown fuse (Dishwasher Repair)
by johnr 3/2/2008 3:51:23 PM(UTC)
Blown Fuse question (Dishwasher Repair)
by Davejb 1/12/2008 4:52:27 AM(UTC)
Blown fuse (Dryer Repair)
by Scottpr 11/25/2007 6:06:35 PM(UTC)
