the fuse in my LG refrigerator burned out and i have had the hardest time tracking down a new fuse. The fuse is soldered to the circuit board and rather than pay $180 for a new circuit board with the fuse... i figured i would simply desolder the old fuse and solder in a replacement. Problem is... i can't find it anywhere. It lists (250V/9A, 125V/15A)... which i take as meaning i could use either one. I have been mostly looking for a 15Amp 125 Volt fuse but can't seem to track it down... plus i don't know the difference between a fast acting fuse, a slow burn fuse, a ceramic fuse, etc. Also if i install a 15A 250V ceramic fuse... will that work just was well?
First it would be prudent to find out what caused the fuse to blow in the first place.
that is a good point... I thought about that and the possibility of the fuse blowing out again if there is another underlying problem. Unfortunately, I don't quite know how to go about figuring out if there is another issue that caused the fuse to burn out.
any suggestions?
I'll research this for you; but perhaps an LG expert might pick up on this and recognize a problem characteristic I'm unfamiliar with.
I found an economical repair for the blown fuse problem that seems to be quite common on LG brands and GE brands. Please contact me if interested.
what is the fix for blown fuse for lg lfc 23760 refrigerator
