primosalon
#1 Posted : Tuesday, June 11, 2013 9:20:32 AM(UTC)
primosalon
hello all and thanks for looking. I have an lg dryer and when I hit start all I get is a humming noise. Any help would be greatly appreciated
#2 Posted : Tuesday, June 11, 2013 12:50:06 PM(UTC)
Sounds like a motor problem.
A make and model number may help others help you.
deleon79
#3 Posted : Tuesday, June 11, 2013 7:28:17 PM(UTC)
deleon79
whirlpool dryer ldi5751 stopped working mid cycle
#4 Posted : Thursday, June 13, 2013 1:48:38 AM(UTC)
I cannot find any info on the given model number.
If you are sure that the humming is coming from the motor, try manually rotating the drum in the correct direction. It should turn fairly easily.
If it does then odds are that your motor needs replacing.
Could also be that it is clogged solid with lint and this is jamming the centrifugal switch mechanism in the activated position.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
