Sawfish
#1 Posted : Tuesday, May 28, 2013 4:53:39 PM(UTC)
Sawfish
Lights are on. Fans are running. Not cooling due to compressor not running. Help, please. Thanks.
#2 Posted : Wednesday, May 29, 2013 12:31:27 AM(UTC)
Check the compressor, should be warm and vibrating and the condenser coils warm all over.
Sawfish
#3 Posted : Wednesday, May 29, 2013 7:11:16 AM(UTC)
Sawfish
Compressor not warm or vibrating. After plugging the refrigerator in, the compressor makes a low humming/buzzing sound with slight vibration for a few seconds. Then there is an audible click, and everything stops. Sounds like a switch/relay in the compressor control box.
#4 Posted : Wednesday, May 29, 2013 8:38:53 AM(UTC)
If you have a meter, check for a compressor short to ground. If no meter, you can try a new start device AP3119971, just follow the directions with the kit.
Sawfish
#5 Posted : Wednesday, May 29, 2013 1:33:52 PM(UTC)
Sawfish
Thank you.
Compressor Problem (Refrigerator & Freezer Repair)
by teton 5/3/2017 7:03:22 AM(UTC)
Whirlpool compressor problems? (Refrigerator & Freezer Repair)
by brtree31 9/19/2011 1:12:08 PM(UTC)
compressor problems (Refrigerator & Freezer Repair)
by Phidolla 5/10/2011 1:12:05 PM(UTC)
Whirlpool 22 cu Ft Compressor problem? (Refrigerator & Freezer Repair)
by stonews 8/2/2010 4:54:19 PM(UTC)
Compressor Problem? (Refrigerator & Freezer Repair)
by fishguy 11/27/2009 10:49:40 AM(UTC)
possible compressor problem!? (Refrigerator & Freezer Repair)
by dannydan 7/8/2009 6:19:54 PM(UTC)
Repost on Amana compressor problem (Refrigerator & Freezer Repair)
by Legend in Your Mind 4/25/2009 2:41:18 PM(UTC)
by brainwayne 4/17/2009 8:12:41 PM(UTC)
Compressor problems? (Refrigerator & Freezer Repair)
by bwmcclenahan 2/10/2009 6:17:35 AM(UTC)
GE refrig compressor problem (Refrigerator & Freezer Repair)
by EPA570 12/27/2008 1:31:37 PM(UTC)
Water Cooler Compressor Problem (General Talk)
by harrymckee 10/30/2008 3:51:13 AM(UTC)
compressor problem? (Refrigerator & Freezer Repair)
by khoffman 7/7/2008 12:45:54 PM(UTC)
Refrigerator Compressor Problem (Refrigerator & Freezer Repair)
by ptmoy 3/15/2008 4:36:10 PM(UTC)
by go2geezer 3/8/2008 1:37:08 PM(UTC)
how do you know if you have a compressor problem or if you just need more freon? (Refrigerator & Freezer Repair)
by shane 9/10/2007 10:00:01 AM(UTC)
