brtree31
#1 Posted : Monday, September 19, 2011 1:12:08 PM(UTC)
brtree31
Refrigerator won't cool. Compressor clicks on for 14 seconds and then clicks off. Prior to problem I smelled an electrical burn smell. There are no burned wires and the fan and lights work OK. The compressor doesn't show any external evidence of over heating. I am familiar with electrical measurements. Can I do a voltage or Ohm check on the compressor to see if it is OK?
#2 Posted : Tuesday, September 20, 2011 1:41:24 AM(UTC)
Pry the compressor side cover off and check the start device, probably burned. Replace it with part AP3885081
brtree31
#3 Posted : Tuesday, September 20, 2011 5:31:35 AM(UTC)
brtree31
Thanks, I will give that a try and let you know
brtree31
#4 Posted : Friday, September 23, 2011 12:45:02 PM(UTC)
brtree31
It worked. Thanks
