j2campeau
#1 Posted : Wednesday, April 22, 2009 4:58:16 PM(UTC)
j2campeau
I have a dryer that does not start,also the heat is low, took forever to dry.would this be therma high limit and heat element
#2 Posted : Thursday, April 23, 2009 3:47:16 AM(UTC)
Replacement parts for MAYTAG PYE4500AZW | AppliancePartsPros.com
Note the wiring diagram included with the above is wrong, it is for a gas dryer.
Here is one that should be close to yours. It is for a PYE4557.
http://www.appliancepartspros.c...ect/i/e/j/iejjhajfjf.gif
If you do not have the correct one, check in the control console, they like to hide them in there.
Sounds like you have 2 problems. Though the low heat symptom indicates a heating problem which may have blown the thermal fuse. See Item 5 in the "Heater" section, note it comes with a new high limit.
Unplug the unit and check the thermal fuse with a meter.
If blown you will want to check the heater for a grounded element also clean and check the vent system. Best to find the cause of the low heat before replacing the fuse. The symptom is low heat but high heat is required to blow the fuse, most likely is an air flow problem either the vent system or the blower.
Also check that the cycling thermostat's contacts open. I usually just heat the face up with a soldering gun but you could also heat it up on a stove element.
You could remove the wires from the thermal fuse, short them together, tape them up and run the unit so you can diagnose/repair the low heat problem.
This is for diagnosis only, do not leave the unit like this as the thermal fuse is a critical safety device.
If you do not own a meter I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
j2campeau
#3 Posted : Thursday, April 23, 2009 8:16:31 AM(UTC)
j2campeau
thanks for the info denman I will troubleshoot
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
