I have a Whirlpool washer (model LSC9355EQQ) that is leaking small amounts of water from the front underside when the machine is in the rinse cycle. I thought it might be loose hose connections at the pump but I checked and it doesn't seem to be that. I can't seem to trace where the leakage is coming from. Could the pump housing be cracked and need replacing? Do these usually go bad? Any suggestions?
I would look at the back side of the pump,(where the motor drives it) If you see a streak around that area, replace the pump!!!!:)
