Pam Zeller
#1 Posted : Sunday, February 6, 2011 12:34:22 PM(UTC)
Pam Zeller
I have a GE Artica PSS27GNA and both the fridge and freezer are not cooling. The fans appear to be working but it is not getting cold. Any help would be appreciated.
#2 Posted : Monday, February 7, 2011 10:23:44 AM(UTC)
For a model # PSS27SGNA, probably a bad motherboard AP4436216 or a bad compressor, although rare for modern GE's.
Joe / APP Team
#3 Posted : Monday, February 7, 2011 10:30:44 AM(UTC)
Joe / APP Team
Pam,
There are several components involved to make the system cool,
Attached is the basic service manual,
KUDP02.pdf (251kb) downloaded 55 time(s).
You should be able to walk your way through the test procedures and have a good idea of which direction to take.
File Attachment(s):
Arctica Profile GE Side-by-Side Refrigerator.pdf (1,717kb) downloaded 80 time(s).
TherapyProvider
#4 Posted : Saturday, May 4, 2013 11:50:44 PM(UTC)
TherapyProvider
Thank you all who has posted in this forum. GE Arctic Model PSS27SGNA How to fix the freezer not hold temp? I just fix this problem, Special thanks to the person who replied to my first response, yes it was lot of lint around back of the unit and lot of lint and dirt covered fan next to the compressor. I tried to clean as much I can by using vacuum. While I was behind the unit I decided to check the motherboard to see if it was shoot or not. Yes different responders in this forum was right. There was a shot/Burn spot back of the big relays area back of the motherboard. As per answer was suggested just a drop of solder work out good and now freezer and refrigerator is working and bring the temperature down. Thanks again for saving the refrigerator without buying new motherboard. :);):D:cool:
#5 Posted : Sunday, May 5, 2013 1:02:39 AM(UTC)
Best to heat up the solder joint well with sufficient solder. The original wave solder process did not wick the solder up the relay pin. This thin solder joint acted as a fuse and blew open during a power surge.
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Fridge and freezer not cooling (Refrigerator & Freezer Repair)
by tommydoggett 4/6/2017 9:39:13 AM(UTC)
Fridge and freezer not cooling temp for both flashing 0 (Refrigerator & Freezer Repair)
by Biggie121 1/25/2016 11:10:41 AM(UTC)
by mousenup2 9/9/2015 5:46:56 AM(UTC)
by Victorgon 3/31/2014 8:16:38 PM(UTC)
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 3/27/2014 4:23:35 PM(UTC)
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 12/27/2013 9:07:11 AM(UTC)
Fridge and Freezer not cooling, (Refrigerator & Freezer Repair)
by jnvo 8/13/2013 4:19:21 PM(UTC)
by jnvo 8/13/2013 4:16:41 PM(UTC)
fridge and freezer not cooling sufficiently (Refrigerator & Freezer Repair)
by Frederickgee 3/12/2013 5:46:11 PM(UTC)
aaaaafridge and Freezer not cooling (Refrigerator & Freezer Repair)
by harrisdb55 10/16/2012 7:11:17 AM(UTC)
Fridge and Freezer not cooling (Refrigerator & Freezer Repair)
by chris4x4gill2 10/4/2012 6:13:38 PM(UTC)
Fridge and freezer not cooling. Fans and compressor working, possible freon leak? (Refrigerator & Freezer Repair)
by Excessumcarcer@yahoo.com 8/12/2012 1:15:41 PM(UTC)
Fridge and Freezer not Cooling properly - GE PTC22SBMARBS (Refrigerator & Freezer Repair)
by DaHadster 5/16/2012 10:19:30 AM(UTC)
by JennyM 4/24/2012 5:27:07 PM(UTC)
