SKITEXAS
#1 Posted : Sunday, April 14, 2013 9:06:19 AM(UTC)
SKITEXAS
replaced power control board per service tech in home, still does the reboot when power is turned off at breaker then back on. but will not stay on inorder to work touch controls HELP ...:confused: could it be the daughter release board ..
SKITEXAS
#2 Posted : Sunday, April 14, 2013 10:04:02 AM(UTC)
SKITEXAS
helo any one out there
#3 Posted : Monday, April 15, 2013 12:37:51 PM(UTC)
HI,
Can you describe the problem more detailed please?
Here are the breakdown diagrams and Parts for GE PP945SM1SS Cooktop - AppliancePartsPros.com
SKITEXAS
#4 Posted : Tuesday, April 16, 2013 3:08:10 PM(UTC)
SKITEXAS
HI,
replaced main board for power and daughter release board but still have same peoblem turn breaker on and after it goes though reboot it turns off the dead nothing
SKITEXAS
#5 Posted : Tuesday, April 16, 2013 3:11:21 PM(UTC)
SKITEXAS
its three years old . it displays though reboot all 8 in sequence then 0245 then it goes dark and will n ot respond >>>> if u would u can call me my email if u want
#6 Posted : Tuesday, April 16, 2013 3:35:49 PM(UTC)
Looks like the problem is a bad touch board which is a part of the glass top. This part is very expensive.
- The glass top Part number: WB62T10568
SKITEXAS
#7 Posted : Tuesday, April 16, 2013 3:48:24 PM(UTC)
SKITEXAS
Thanks I guess it's time to replace total it just pass 2/3
#8 Posted : Tuesday, April 16, 2013 3:58:53 PM(UTC)
I will do the same. It's not worth such money.
GE Cook Top / Sparking from under the knob (Oven Repair (including Ranges and Cooktops))
by nj1971 7/8/2015 8:10:45 PM(UTC)
KitchenAid Electric Range Cook Top no power (Oven Repair (including Ranges and Cooktops))
by coachpelkey 4/7/2014 2:39:46 PM(UTC)
Frigidaire gas range cook top grates (Oven Repair (including Ranges and Cooktops))
by learjetman 12/11/2011 5:39:05 PM(UTC)
New Whirlpool Gas Range Cook Top Ignitors Not Working (Oven Repair (including Ranges and Cooktops))
by stevenwwinters 11/27/2009 10:19:01 AM(UTC)
GE Cook top GAS burner (Oven Repair (including Ranges and Cooktops))
by nima98 6/16/2009 12:53:59 PM(UTC)
Roper range cook top element gets too hot (Oven Repair (including Ranges and Cooktops))
by Dennis11 11/23/2007 8:58:38 AM(UTC)
