replaced power control board per service tech in home, still does the reboot when power is turned off at breaker then back on. but will not stay on inorder to work touch controls HELP ...:confused: could it be the daughter release board ..
Originally Posted by: SKITEXAS  replaced power control board per service tech in home, still does the reboot when power is turned off at breaker then back on. but will not stay on inorder to work touch controls HELP ...:confused: could it be the daughter release board .. helo any one out there
Originally Posted by: Gene  replaced main board for power and daughter release board but still have same peoblem turn breaker on and after it goes though reboot it turns off the dead nothing
Originally Posted by: SKITEXAS  replaced main board for power and daughter release board but still have same peoblem turn breaker on and after it goes though reboot it turns off the dead nothing its three years old . it displays though reboot all 8 in sequence then 0245 then it goes dark and will n ot respond >>>> if u would u can call me my email if u want
Looks like the problem is a bad touch board which is a part of the glass top. This part is very expensive. - The glass top Part number: WB62T10568
Thanks I guess it's time to replace total it just pass 2/3
I will do the same. It's not worth such money.
