amchret8@aol.com
#1 Posted : Wednesday, March 27, 2013 8:41:27 AM(UTC)
amchret8@aol.com
the dryer has had the following parts replacer cycle controler start button
door switch, themral switchs. unit starts heats up and runs fine for about 10 min. and shuts off it can be made to run and work fine by holding the start switch in. what parts do i need to order and replace to fix it
thank you larry jennings
#2 Posted : Friday, March 29, 2013 3:13:15 AM(UTC)
Parts for Whirlpool LER4634JQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
[COLOR="Blue"]
unit starts heats up and runs fine for about 10 min. and shuts off[/COLOR]
I am assuming that the unit shuts off not just the heating coil.
Is that correct?
When it shuts off can you restart it right away or do you have to wait a while?
Having to wait is a a symptom of a motor/drum problem re: the motor is overheating and tripping it's internal thermal protect. You then have to wait for it to cool down so the protect can reset before it will start again.
This does not really match your symptoms as holding the start switch in should not have any effect on the above.
Does it shut off with no clothes in the unit?
My thoughts here is that the latch is bad so the clothes hit the door and open the door switch which shuts the unit off.
This would match your symptoms if it restarts right away after shutting down.
Handles attachments
LER4634.pdf (232kb) downloaded 0 time(s).
Gas Dryer cuts off after 5 mins (Dryer Repair)
by opeter 9/29/2017 12:53:23 PM(UTC)
Dryer cuts off (Dryer Repair)
by roberson3714 10/19/2011 8:44:24 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore stack w/d dryer cuts off after 1 min. PLEASE ADVISE need as much feedback as (Dryer Repair)
by dhompe3 3/23/2011 6:45:50 PM(UTC)
dryer cuts off after running for about 2 min (Dryer Repair)
by jim5sexton 3/2/2011 3:13:04 PM(UTC)
Dryer cuts off then will turn back on after cooled off (Dryer Repair)
by hollywilhite 12/6/2010 6:16:40 PM(UTC)
by Van Johnson 3/21/2010 7:31:49 AM(UTC)
dryer cuts off (Dryer Repair)
by Chris Jensen 6/18/2009 6:10:06 PM(UTC)
The Dryer cuts off (Dryer Repair)
by ineedheep 11/1/2008 7:45:07 AM(UTC)
dryer cuts off after 10 minutes but will start (Dryer Repair)
by 30tredog 10/1/2008 4:01:47 AM(UTC)
by 30tredog 9/30/2008 5:51:35 AM(UTC)
