roberson3714
#1 Posted : Wednesday, October 19, 2011 8:44:24 AM(UTC)
roberson3714
I have a series 90 kenmore dryer that cuts off after about 10 mins. and then cuts back on. This will happen repeatedly until the timer reaches zero. When it cuts off, the timer continues to click. I have replaced the motor, cleaned the entire dryer of lint and made sure the drum rollers operate freely. The drum seems to rotate easily so ther shouldn't be any excess friction causing the motor to heat up. The exhaust vent is also clear. the only thing I haven't rplaced is the timer. Could a bad timer cause this problem?
Joe / APP Team
#2 Posted : Wednesday, October 19, 2011 12:42:16 PM(UTC)
Joe / APP Team
Roberson,
I would not expect a timer issue to be the problem, not based on your description. I would expect a voltge issue to the motor, either high or low voltage, will cause the motor overload to open and stop the motor. You may want to test the motor voltage, or amperage while it is running, and make sure the harness wiring is not shorted or pinched.
If you could get us a model number, it would be a great help.
roberson3714
#3 Posted : Wednesday, October 19, 2011 12:45:59 PM(UTC)
roberson3714
The model number is 110 66912691
Joe / APP Team
#4 Posted : Wednesday, October 19, 2011 1:51:06 PM(UTC)
Joe / APP Team
The model number is 110.66912691
Roberson,
Thanks for the model number, it was a great help.
But the checks you need to make are still the same,
loose connections, pinched or damaged wire harness.
Proper voltage and amperage draw when the motor is running and the heater element is on.
Gas Dryer cuts off after 5 mins (Dryer Repair)
by opeter 9/29/2017 12:53:23 PM(UTC)
dryer cuts off (Dryer Repair)
by amchret8@aol.com 3/27/2013 8:41:27 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore stack w/d dryer cuts off after 1 min. PLEASE ADVISE need as much feedback as (Dryer Repair)
by dhompe3 3/23/2011 6:45:50 PM(UTC)
dryer cuts off after running for about 2 min (Dryer Repair)
by jim5sexton 3/2/2011 3:13:04 PM(UTC)
Dryer cuts off then will turn back on after cooled off (Dryer Repair)
by hollywilhite 12/6/2010 6:16:40 PM(UTC)
Dryer cuts off (Dryer Repair)
by Van Johnson 3/21/2010 7:31:49 AM(UTC)
by Chris Jensen 6/18/2009 6:10:06 PM(UTC)
The Dryer cuts off (Dryer Repair)
by ineedheep 11/1/2008 7:45:07 AM(UTC)
dryer cuts off after 10 minutes but will start (Dryer Repair)
by 30tredog 10/1/2008 4:01:47 AM(UTC)
by 30tredog 9/30/2008 5:51:35 AM(UTC)
