Yenchna
#1 Posted : Sunday, April 19, 2009 1:20:02 PM(UTC)
Yenchna
Do I just nee to replace the heating element? Thanks for any assistance - it's greatly appreciated......:p
applianceman
#2 Posted : Sunday, April 19, 2009 2:19:01 PM(UTC)
applianceman
There are two thermostats on the side of the heater-can that go out just as much if not more than the heater. If you have an ohmmeter check the thermostats and the heater. To check these first disconnect power then remove the wires from the two thermostats. Then use your ohmmeter to see if you have continuity between the terminals. If you do the thermostats are good if not they are bad and needs replacing. If you find that one of the thermostats is bad, replace both of them (they come as a kit). If the thermostats are not bad the heater is the most likely problem. But just to be sure the heater should have about 10 ohms. Once the dryer is fixed check the vent and make sure it is clear because this may have caused your problem. Whirlpool Dryer No Heat Repair Guide
arnie460
#3 Posted : Monday, April 20, 2009 6:11:58 PM(UTC)
arnie460
Check to see if you have 230 volts to dryer. Motor will run on 115 volts, but no heat
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Dryer runs but no heat. (Dryer Repair)
by Elarde 6/18/2015 1:17:00 AM(UTC)
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 1/28/2015 2:49:23 PM(UTC)
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 11/19/2012 4:56:14 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
Dryer runs but no heat (Dryer Repair)
by barglancy 9/26/2011 4:44:08 PM(UTC)
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 6/27/2011 7:31:38 PM(UTC)
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 3/10/2011 8:08:45 PM(UTC)
by sdean 2/8/2011 2:05:25 PM(UTC)
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 1/31/2011 9:02:20 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
by glenn906 7/1/2010 11:14:54 AM(UTC)
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 5/21/2010 12:06:37 PM(UTC)
by katyld 1/27/2010 3:06:34 PM(UTC)
by je24995 12/13/2009 11:19:31 AM(UTC)
