2 Pages12>
pordlawk
#1 Posted : Monday, February 25, 2013 7:18:58 PM(UTC)
pordlawk
I was helping move a refridgerator and the water line got snagged and severely stretched.This is the water line that goes between house water supply and water filter under the fridge. I'm not sure of (1)the part number or (2)how to disconnect water line from filter assembly. (3)Also this line was way too short to reach the house water supply. It's going to have to somehow be extended. Any help will be greatly appreciated. Thanks.
pordlawk
#2 Posted : Thursday, February 28, 2013 3:45:03 AM(UTC)
pordlawk
tap, tap, tap Hello, Is this thing on?
Joe / APP Team
#3 Posted : Thursday, February 28, 2013 9:05:13 AM(UTC)
Joe / APP Team
Pordlawk, First off, the house water supply line does not attach to the filter housing, it is attached to the water inlet valve
Part number: AP5263471
The water tube routes from the fill valve to the water filter housing
Part number: AP4369390
Then from the housing to the reservoir/tank
Part number: AP3181346
and from the reservoir/tank to the dispenser on the freezer door.
The tubes attach to the components by way of "john guess" fittings, they are self sealing compression fittings. To release the water tube from the fitting, press in or down on the plastic collar that surrounds the water tube, and pull out on the tube. To reseat the tube, press in or down on the collar, insert the tube as far as possible, release the collar and slightly tug on the water tube to make sure it is seated and locked in position.
You'll need to determine which tube has been damaged and order the appropriate part from the parts diagram, or let us know which tube and we can assist with the parts research .
pordlawk
#4 Posted : Saturday, March 2, 2013 4:33:26 AM(UTC)
pordlawk
Thanks for all the info. I don't remember it being anything like the video. I can get another look at it this weekend and get back with you. Again, thanks.
Joe / APP Team
#5 Posted : Saturday, March 2, 2013 6:13:31 AM(UTC)
Joe / APP Team
OK, Will keep an eye out for the next post.
pordlawk
#6 Posted : Monday, April 1, 2013 1:20:16 PM(UTC)
pordlawk
Sorry it took so long to get back. After a 2nd look, the only place to hook up water to the fridge is this stretched hose. It has, what I believe is a brass 1/4", fitting that screws on house water supply.It has a male to male adapter screwed in it because it needs an extension. It only reaches about a foot out of the fridge. The other end has a 'john's guess' fitting on the other end, that is attached to the filter housing. There is another line coming out of the filter housing that connects to the water inlet valve. I hope I'm not losing my mind here.
Joe / APP Team
#7 Posted : Tuesday, April 2, 2013 6:04:22 AM(UTC)
Joe / APP Team
Pordlawk, You're not losing your mind, you are correct in your observance and routing of your water dispenser tubes, we were wrong. After reviewing the available information and the routing of the tubes, you will need to order and replace
Part number: AP3175465
This is the tube that attaches to the "double male" connector on the water supply tube and attaches to the filter housing by way of the "john guess" fitting on the housing.
Sorry for the misdirection. Thanks
pordlawk
#8 Posted : Friday, April 5, 2013 3:44:22 AM(UTC)
pordlawk
Thank you...
Joe / APP Team
#9 Posted : Friday, April 5, 2013 5:58:06 AM(UTC)
Joe / APP Team
Thank you...
You're Welcome !
We'd appreciate a Report when you're done. It could be helpful to others reviewing the forum.
pordlawk
#10 Posted : Monday, April 8, 2013 4:12:27 AM(UTC)
pordlawk
One more thing. The stretched tube I have has factory ends on both ends.One end is kind of a flare (?) that seats between 1/4 nut and male to male adapter. The other end that goes into the john's guess fitting is a larger (5/16")outside diameter than the rest of the tube(1/4"). The 1/4 nut is trapped between these two ends and won't come off. This doesn't appear to be the case with the tube in the picture you provided. Also, my tube is approx. 3' long including 3" stretch. Okay, duh... Sitting here looking at my tube it has a number printed on it. 2319867. I bet that's gonna be some help.
Guest (4)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 3/15/2024 12:21:35 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
LG WM3050C cold water inlet hoses orientation (Washer Repair)
by Guest 3/12/2023 10:12:07 AM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Bosch “Water Inlet” Stains/Mold? (Dishwasher Repair)
by Crsanders 6/4/2022 7:48:52 AM(UTC)
Bosch dishwasher water inlet vent hole leak (Dishwasher Repair)
by cmt21h 12/11/2021 7:59:08 AM(UTC)
GE Dishwasher water inlet solenoid (Dishwasher Repair)
by botemon 11/3/2021 10:07:48 AM(UTC)
Cant find the part I need for water inlet (Refrigerator & Freezer Repair)
by feedlebum 7/16/2021 7:50:43 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
2 Pages12>
