Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I replaced the cold water Inlet valve and it had 3 hoses, I know one of the hoses I put back for sure at it’s appropriate valve, the other 2 while I am 99% sure I put them at the right place I am worried what happens if I didn’t, is there a place or way to see where they should be plugged into at the inlet valve, and what happens if those other 2 hoses are inverted and
Groups: Expert
Rank: Guest
Thank you for replying, its operating normally as before, so I’m sure they are in their proper position, but do you know what the symptoms would be if two of the hoses were switched?
Groups: Expert
I'm not familiar with this particular brand, but on most washers, the hoses go to the drawers that dump the bleach and softener into the washer so it would probably be reversed. If its washing fine, its probably ok.
Rank: Guest
Thanks for the clarification and I really appreciate your help. It is washing perfectly fine, so I’m gonna go with that. =)
