juliechilders
#1 Posted : Friday, April 17, 2009 6:36:57 AM(UTC)
juliechilders
I Think The Thermostat Cut Off Is My Problem. Is It Suppose To Be Closed Or Open??????
#2 Posted : Friday, April 17, 2009 6:55:34 AM(UTC)
Model Search
Cannot find anything on B42, there is a BL2 and a BW2.
Should be closed (0 ohms)
juliechilders
#3 Posted : Friday, April 17, 2009 7:03:04 AM(UTC)
juliechilders
Thanks denman, we bypassed the thermal cut off and it worked. Now, what else do i need to check? obviously it must have got too hot. Do you suggest just cleaning any extra lint and replace the cut off or do i need to check something else?
#4 Posted : Friday, April 17, 2009 7:49:58 AM(UTC)
Not sure which one you are talking about, there are 2 in this unit.
Will assume it is the one on the blower. It kills power to the motor the following also applies to the other one (just shuts off the heating element), it has more things to check as it is further back in the circuit.
The most common cause of it blowing is a dirty vent system or the outside vent louvers are not opening.
Could also be that the blower wheel has come loose from the motor or it is clogged up with lint.
On a rare occasion the cycling thermostat's contacts are welded together.
Also check your lint filter, if you use too much fabric softener it can coat the screen and drastically reduce air flow. If coated just clean it with soap and water.
Guest (4)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
