Have a Kenmore Washer that fills about an inch and a half of water in the tub right before the tub completes its final spin. It was totally out of sorts before I changed the timer. Could the 2nd rinse switch be the culprit?
Tom
Groups: Expert
Probably the load sense switch. This is a high failure item in this washer and will give the symptom that you have if faulty. Eric
