2 Pages<12
#11 Posted : 12 years ago
The BEST stuff I ever found was at Walmart non-residue contact cleaner by CRC $4.95, so "liquid" it will penetrate any small opening and displace oil and contaminents.
bigalp45
#12 Posted : 12 years ago
bigalp45
I ended up changing the cold control but I have noticed that the refrigerator has run for about 6 hours straight. It was a pretty easy install, is it possible that I did something wrong or is this normal? Maybe it could be the defrost timer???
#13 Posted : 12 years ago
As lons as you routed the sensing tubing from the control exactly were the old one was, you should be ok. If the fridg was warm, it takes up to 12 hrs to reach temperature.
bigalp45
#14 Posted : 12 years ago
bigalp45
The system is cycling on and off now but the refrigerator seems a lot colder than before. Previously to changing the cold control, I had the temperature setting at "3" out of a possible 1 to 5, I now have it set below "1" and the refrigerator still seems colder than it should be. It just seems to be running more than is needed.
#15 Posted : 12 years ago
The fridg temperature should ba around 41 degrees.
#16 Posted : 12 years ago
Check the freezer temperature, should be lower than 5 degrees if running a lot.
bigalp45
#17 Posted : 12 years ago
bigalp45
I still need to get a refrigerator thermometer. Thanks!
GE monogram zisb360dri refrigerator problem (Refrigerator & Freezer Repair)
by aryehsternman 4 years ago
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 5 years ago
Refrigerator problem (Refrigerator & Freezer Repair)
by Janet P. 10 years ago
Refrigerator Problems (Refrigerator & Freezer Repair)
by thshen34 10 years ago
Whirlpool refrigerator problem - Ideas? (Refrigerator & Freezer Repair)
by RMO87 11 years ago
Kenmore Coldspot refrigerator problem (Refrigerator & Freezer Repair)
by repair123 12 years ago
Kenmore side by side refrigerator problems (Refrigerator & Freezer Repair)
by suespoppy@aol.com 12 years ago
Kenmore refrigerator problem (Refrigerator & Freezer Repair)
by Nate H 12 years ago
frigidaire refrigerator problem (Refrigerator & Freezer Repair)
by ricksfund85 13 years ago
GE Profile Refrigerator Problem (Refrigerator & Freezer Repair)
by six_pack 13 years ago
Kenmore (Amana) Refrigerator Problems (Refrigerator & Freezer Repair)
by JDB59 13 years ago
by duff1234 14 years ago
Refrigerator problem, Need help please. (Refrigerator & Freezer Repair)
by jbyoung 14 years ago
GE Refrigerator Problems (Refrigerator & Freezer Repair)
by phx1hab 14 years ago
2 Pages<12
