wayfran67@q.com
#1 Posted : Tuesday, January 8, 2013 7:36:37 AM(UTC)
wayfran67@q.com
When my refrig. comes off defrost it makes a clicking noise
at least 3-4 times before the compreesor starts.
Does not do this on normal starts.
I put a watt meter on it and when it clicks and does not pull
hardly any more watts. like it wound if the compressor was trying to start.
I changed out the defrost unit ,no help.
What's next the overload relay ?
Thank's Wayne
rickgburton
#2 Posted : Tuesday, January 8, 2013 10:13:14 AM(UTC)
rickgburton
Groups: Expert
Hi Wayne, it's not watts you want to check but amps. It sounds like the relay/overload/start device may be faulty. I can't get anything to come up with that number. Read it off the tag in the fresh food section and not off any stickers on the door.
wayfran67@q.com
#3 Posted : Tuesday, January 8, 2013 12:44:47 PM(UTC)
wayfran67@q.com
Here is the model from the label in side the box.
Model BC20JL Amana
Mgf # P7680812WL
sn. # 8701025320
I looked at watts and anps, didn't pull much trying to start
not as much as running normal, which is about 8/9 amps
Thank's Wayne
rickgburton
#4 Posted : Tuesday, January 8, 2013 1:34:55 PM(UTC)
rickgburton
Groups: Expert
8 or 9 amps running? That's way too much. I don't know why I can't get anything to come up with that number. Are you in the USA? Try replacing the start device. It's either that or the compressor.
wayfran67@q.com
#5 Posted : Thursday, January 10, 2013 5:56:41 AM(UTC)
wayfran67@q.com
I told you wrong on the amp draw while running is 3 amps
defrost amps is 4
When it tries to start after defrost mode it jumps to 20 amps
and kicks out, does this serveral times before the compressor
starts. I haven't recorded amps on normal start.
Thanks, Wayne
I have since recorded start amps it's 3 amps.
Home Owner (Refrigerator & Freezer Repair)
by Dennis Steen 6/4/2015 8:29:00 AM(UTC)
home owner (Dishwasher Repair)
by dalmil 9/23/2011 6:21:22 AM(UTC)
Home Owner (Washer Repair)
by kdchase 3/28/2011 3:43:45 PM(UTC)
by kdchase 3/27/2011 4:47:16 PM(UTC)
home owner (Washer Repair)
by AtollMan 9/12/2010 8:31:11 AM(UTC)
home owner (Oven Repair (including Ranges and Cooktops))
Belarus louismok 8/9/2010 1:43:29 PM(UTC)
Storm. home owner (Oven Repair (including Ranges and Cooktops))
by Storm Totten 7/27/2010 3:06:12 PM(UTC)
getting GE to send part to home owner (Refrigerator & Freezer Repair)
by lmm 1/4/2010 2:36:35 PM(UTC)
by KLOPS 8/3/2009 12:15:51 PM(UTC)
by tom ponsford 3/11/2009 8:17:13 AM(UTC)
home owner (Dryer Repair)
by portincaso 5/24/2008 2:26:38 PM(UTC)
