I Have A Gibson Upright Freezer That When You Open And Then Close The Door The Door Will Not Stay Shut It Comes Back Open About One Inch Is The Door Seal Or Gasket Bad Or Can It Be Cleaned So It Wiil Pull Itself To The Out Side Door Front Of The Freezer
Check to see that the unit is level.
