2 Pages12>
bigalp45
#1 Posted : Wednesday, December 12, 2012 12:16:34 PM(UTC)
bigalp45
I have a 16 year old side by side unit that I suspect has a faulty thermostat. I am only a novice and home owner. The unit does not come on and shut off like it should, but I noticed that if I tap on the panel where the temp. controls are located, the unit does come on and runs fine, but it may run for several hours before it shuts off. The next day, I have to again tap on this panel to make the unit run. Once I force it on, it cools fine, makes ice, etc. but there is definitely some problem. Before I have a service man come out, I would like to able to explain to them the problem. Does this make any sense? Any suggestions?
#2 Posted : Thursday, December 13, 2012 12:33:30 AM(UTC)
Drop the control panel and tap on the cold control and defrost timer, one of them might be intermittent, probably the cold control. If the control is bad, order a new one on this site.
#3 Posted : Thursday, December 13, 2012 3:13:28 AM(UTC)
Perhaps try gently turning the control up/down a bit (not to off).
If it fires up then the control thermostat is the more likely cause.
bigalp45
#4 Posted : Thursday, December 13, 2012 4:40:50 AM(UTC)
bigalp45
There are two temperature controls next to each other, one for the freezer and one for the refigerator temps. I am guessing that I should turn the control for the refrierator?
bigalp45
#5 Posted : Thursday, December 13, 2012 4:43:24 AM(UTC)
bigalp45
I am somewhat mechanical, but is replacing this cold control something that I can do, or does it require a serviceman?
#6 Posted : Thursday, December 13, 2012 3:30:53 PM(UTC)
You should be able to replace it.
bigalp45
#7 Posted : Thursday, December 13, 2012 6:35:29 PM(UTC)
bigalp45
I tried turning the refrigerator temp. control knob to "coldest" and then back to #2, back and forth about 5 times but the unit did not start. I then tapped the panel and the unit did start, and ran for about three hours. I noticed that later in the day, the unit was running without having to tap the panel, or force it on.
#8 Posted : Friday, December 14, 2012 12:47:14 AM(UTC)
I would spray the cold control and any connector while moving the control back and forth and unplugging the connector, one of them is intermitent.
#9 Posted : Friday, December 14, 2012 1:46:24 AM(UTC)
Yes it could be a bad connection.
Or since the temperature control did not start the unit up, it could be a bad defrost timer.
bigalp45
#10 Posted : Friday, December 14, 2012 4:14:43 AM(UTC)
bigalp45
Richappy, you suggested to spray the cold control while turning it. What should I spray it with?
GE monogram zisb360dri refrigerator problem (Refrigerator & Freezer Repair)
by aryehsternman 10/11/2020 5:18:56 PM(UTC)
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 8/12/2020 7:40:47 AM(UTC)
Refrigerator problem (Refrigerator & Freezer Repair)
by Janet P. 5/22/2015 7:29:28 AM(UTC)
Refrigerator Problems (Refrigerator & Freezer Repair)
by thshen34 12/9/2014 7:17:28 AM(UTC)
Whirlpool refrigerator problem - Ideas? (Refrigerator & Freezer Repair)
by RMO87 2/8/2014 2:24:24 PM(UTC)
Kenmore Coldspot refrigerator problem (Refrigerator & Freezer Repair)
by repair123 8/20/2013 3:05:06 AM(UTC)
Kenmore side by side refrigerator problems (Refrigerator & Freezer Repair)
by suespoppy@aol.com 3/11/2013 11:17:56 PM(UTC)
by suespoppy@aol.com 3/11/2013 10:33:57 PM(UTC)
Kenmore refrigerator problem (Refrigerator & Freezer Repair)
by Nate H 10/25/2012 6:11:42 PM(UTC)
frigidaire refrigerator problem (Refrigerator & Freezer Repair)
by ricksfund85 6/25/2012 9:14:37 AM(UTC)
GE Profile Refrigerator Problem (Refrigerator & Freezer Repair)
by six_pack 4/5/2012 7:34:56 PM(UTC)
Kenmore (Amana) Refrigerator Problems (Refrigerator & Freezer Repair)
by JDB59 12/26/2011 10:31:56 AM(UTC)
by duff1234 9/2/2011 6:58:39 AM(UTC)
Refrigerator problem, Need help please. (Refrigerator & Freezer Repair)
by jbyoung 8/9/2011 3:52:06 PM(UTC)
GE Refrigerator Problems (Refrigerator & Freezer Repair)
by phx1hab 6/17/2011 7:41:09 AM(UTC)
2 Pages12>
