mayork
#1 Posted : 12 years ago
mayork
I am having problems with my dryer staying on. It is turning on and seems to be working fine (heating up to dry), BUT then is turning itself off after a few minutes. I have replaced the vent hose, and outside vent...hoping that this would fix the problem due to possible clogging, but this did not help at all. Can anyone please tell me what parts would fix this problem?
Thank You,
MAY
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Does the dryer stops all together or only heating part?
What do you do to restart it?
It sounds like dying motor.Remove the front panel and clean the motor from the lint. See if that helps.
Post he results.
Simon.
mayork
#3 Posted : 12 years ago
mayork
The dryer just stops all together. It was working just fine before this. I have never before had a problem.
I just hit the start button to turn it back on. It will ONLY restart after it has cooled down inside the dryer.
Thanks so much,
Marsha
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Clean the motor first and if that doesn't help -replace it
Part number: 279827
Part number: 279827
Here are the breakdown diagrams and Parts parts for Whirlpool LER5636EQ0 - AppliancePartsPros.com
Simon.
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 3 years ago
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 6 years ago
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 7 years ago
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 10 years ago
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 10 years ago
whirlpool electric dryer (Dryer Repair)
by ajlgap19 11 years ago
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 11 years ago
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 11 years ago
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 11 years ago
by eisehunter 12 years ago
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 12 years ago
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 12 years ago
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 13 years ago
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 13 years ago
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 13 years ago
