2 Pages12>
harold2
#1 Posted : Monday, October 1, 2012 11:09:01 AM(UTC)
harold2
The ice maker on my frigidare side-by-side is not making ice. I am still getting water at the water dispenser and if I pour water into the tray manually it will eject icecubes in the normal time. I think the water valve may be bad, although it is still suppling water to the water dispenser. is there a reset switch?
#2 Posted : Tuesday, October 2, 2012 12:43:14 PM(UTC)
Swap the wires between the ice maker and the water dispenser solenoids at the water inlet valve. Push the water dispenser lever for a few seconds and check for water in the ice maker.
If there is no water, replace the water valve.
If there is water, replace the ice maker.
- The water valve Part number: 241734302
harold2
#3 Posted : Tuesday, October 2, 2012 3:37:30 PM(UTC)
harold2
Thanks Gene, but I already bought the water valve - so I will put it in. But I will try swapping the wires first.
#4 Posted : Tuesday, October 2, 2012 3:42:06 PM(UTC)
harold2
#5 Posted : Wednesday, October 10, 2012 3:33:49 PM(UTC)
harold2
Re: frigidare FRS23LH5DS0 side-by-side.
I replaced the water valve and the Icemaker - Still no ice? I have water to the back of the icemaker, but it is not filling the tray when I rotate the paddles to 7:00 o clock postion. What now?
#6 Posted : Thursday, October 11, 2012 2:51:08 PM(UTC)
Have you checked the water tube into the ice maker for any blockage and/or ice inside?
harold2
#7 Posted : Thursday, October 11, 2012 3:06:35 PM(UTC)
harold2
Yes, I checked the water tube up to the point where it enters the back of the refrigerator behind the freezer, and I defrosted the freezer to allow any ice inside time to melt (about and hour). Do you think it needs more time to thaw?
#8 Posted : Thursday, October 11, 2012 3:22:01 PM(UTC)
I would disconnect the ice maker tube (1/4") from the water valve and blow some air through the tube.
harold2
#9 Posted : Thursday, October 11, 2012 3:31:50 PM(UTC)
harold2
Thanks gene. Already started. Also, I hit the fill tube with a hair dryer and a chunk of ice slid out. I am re-connecting the IM.
harold2
#10 Posted : Thursday, October 11, 2012 3:59:12 PM(UTC)
harold2
Finally, there is water in the ice tray. . . . we'll see.
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Frige 2014 no Ice & frige is 50 degrees (Refrigerator & Freezer Repair)
by Plus160 7/5/2023 5:05:07 PM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
GE Cafe Refrigerator No Ice (Refrigerator & Freezer Repair)
by amappliancewi 2/8/2023 5:22:22 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
No Icecream at night - Freezer stops cooling around 8PM and everything is Frozen by 8AM. - (Refrigerator & Freezer Repair)
by usercraig 3/7/2022 7:40:11 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
Samsung RS265TDRS Not Cooling/No Ice (Refrigerator & Freezer Repair)
by Guest 5/31/2021 10:09:58 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
** RESOLVED ** Subzero 590, no ice (Refrigerator & Freezer Repair)
by Intel1919 9/12/2020 9:54:24 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
GE Profile Artica no ice but passes check (Refrigerator & Freezer Repair)
by phatcher 4/1/2020 2:01:31 PM(UTC)
2 Pages12>
