3 Pages123>
alhero
#1 Posted : Thursday, October 11, 2012 1:24:52 PM(UTC)
alhero
At first there was a noice coming from the top of the refrigerator. I think it was the condeser Fan. Now the fan does not start and the lights in the control panel blink on and off. The refrigerator seems not to cool up to the set degrees. Also, The condeser coils on top of the refrigerator are very hot.
Do I need to replace the condenser fan??
Need help. I live in a rural area and the repair company doesn't seem to know what the problem is. Not sure if they have ever worked on a sub zero system.
Simon / APP Team
#2 Posted : Thursday, October 11, 2012 3:14:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will need to replace the main control board
Part number: W10219462
and the condenser fan motor Part number: 2188874
Here are the breakdown diagrams and Upper Unit parts for Whirlpool KSSC42QVS01 - AppliancePartsPros.com
Good luck. Post the results.
Simon.
alhero
#3 Posted : Friday, October 12, 2012 10:21:33 AM(UTC)
alhero
Hi Simon:
Sorry, but I made a mistake and provided the wrong model number. I used the book I had and it seems to be the wrong user manual. I checked in the refrigerator and the correct number is:
KSSC48QMS02
I was hoping it was only the fan, but you think it is also the control Board?
Thanks for the help. Hopefully it is an easy install.
Al
Simon / APP Team
#4 Posted : Friday, October 12, 2012 10:44:06 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Use the multimeter to check if there is 120VAC at the condenser motor. If you are lucky and the correct voltage present, replace the motor only Part number: W10181323
Here the breakdown diagrams and Upper Unit parts for Whirlpool KSSC48QMS02 - AppliancePartsPros.com
Good luck.
Simon.
alhero
#5 Posted : Wednesday, October 17, 2012 11:43:19 PM(UTC)
alhero
Hi Simon:
What is the correct part number for the control panel if I need it.
Model # KSSC48QMS02
Thanks for all your help.
Simon / APP Team
#6 Posted : Thursday, October 18, 2012 7:55:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the control panel breakdown diagram and Control Panel parts for Whirlpool KSSC48QMS02 - AppliancePartsPros.com
Simon.
alhero
#7 Posted : Sunday, October 21, 2012 7:58:46 PM(UTC)
alhero
Hi Simon:
Sorry for the delay. The system is located in my vacation home and I can only get to it over the weekend.
Where is the condenser motor?
I restarted the system after a week and the fan started up immediately. The control lights come on and it seemed that the frig was working fine. After about two hours the fan turned off and the system would not cool down any longer. I also hear a faint noice close to the on and off switch (a slight clickin)
I need to know if I need control board under the lights in the frig. or the main control board. The fan seems to work fine.
Al
Simon / APP Team
#8 Posted : Monday, October 22, 2012 8:51:07 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The condenser fan motor is on the top left close to compressor. You need to replace the main control board up on the top. It's no longer available. You need to contact the Whirlpool on this issue. In you previous post you stated that the condenser fan motor doesn't work and that's why I suggested to replace it. So does it work? If it's not - replace it too.
Simon.
alhero
#9 Posted : Friday, October 26, 2012 10:45:49 AM(UTC)
alhero
Hi Simon:
Well I purchased the control panel. Installed without a problem. The system started up just fine. Both fans were working. The condencer fan after an hour turned off, the system is still cooling but the coils are very warm and the panel by the doors are also warm. Not sure if this is normal. The system has not cooled down to the normal amount. I hope the condenser fan not working will not damage anything else. I am also concerned with the panels in the refrigerator being warm.
Let me know if this is normal.
Al
Simon / APP Team
#10 Posted : Friday, October 26, 2012 1:04:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Turn off the refrigerator ASAP - you will kill the compressor.
Why did you replace the control panel instead of the control board up on the top?
Simon.
Guest (4)
Kscs25fvms01 kitchen aid refrigerator (Refrigerator & Freezer Repair)
by Guest 9/10/2021 1:42:56 PM(UTC)
Kitchen Aid refrigerator click buzz click - not cooling (Refrigerator & Freezer Repair)
by adfonseca 3/11/2021 3:18:11 PM(UTC)
Kitchen Aid Refrigerator Issue (Refrigerator & Freezer Repair)
by vta1605 2/25/2021 9:45:52 AM(UTC)
Kitchen Aid Refrigerator KSC24C8EYY02 (Refrigerator & Freezer Repair)
by Carlos trio 5/18/2020 12:53:17 PM(UTC)
Loud intermittent sound from Kitchen Aid Refrigerator (Refrigerator & Freezer Repair)
by Adam_W 4/18/2018 9:01:28 AM(UTC)
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 10/26/2016 5:27:11 PM(UTC)
Kitchen aid refrigerator water filter/housing leak (Refrigerator & Freezer Repair)
by timspillane 3/18/2014 7:27:33 AM(UTC)
Kitchen Aid Refrigerator LED Display not working (Refrigerator & Freezer Repair)
by TroyJ 1/17/2014 3:02:20 PM(UTC)
by alhero 5/8/2013 11:52:27 AM(UTC)
Kitchen aid refrigerator with a non working ice maker (Refrigerator & Freezer Repair)
by ts6268 1/18/2013 10:08:47 AM(UTC)
Replacing door gasket seal on side by side Kitchen Aid Refrigerator (Refrigerator & Freezer Repair)
by curtisn 11/20/2012 3:00:41 PM(UTC)
Kitchen Aid Refrigerator Ice Maker Not Working (Refrigerator & Freezer Repair)
by Dan0354 12/6/2011 6:51:54 PM(UTC)
Fix 1987 Kitchen Aid Refrigerator or buy new? (Refrigerator & Freezer Repair)
by hanswagner 9/6/2011 1:12:04 PM(UTC)
Problem with kitchen aid refrigerator kbfa25erss01. (Refrigerator & Freezer Repair)
by AMINAZIZ 6/21/2011 9:55:44 AM(UTC)
Kitchen Aid Refrigerator Freezer not cool enough (Refrigerator & Freezer Repair)
by mjmock 6/15/2011 1:56:20 AM(UTC)
3 Pages123>
