kurtrup
#1 Posted : Sunday, July 15, 2012 6:54:21 PM(UTC)
kurtrup
my washer stops before the final spin cycle and tub is full of water.when it stops there is a humming noise that lasts for 20 seconds. it sits for a while and resets like an overload switch would,sometimes works sometimes not. i replaced the timer which seemed to help at first but im still having the problem.
Simon / APP Team
#2 Posted : Monday, July 16, 2012 11:55:06 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the correct model number of the washer.
Simon.
kurtrup
#3 Posted : Monday, July 16, 2012 3:54:50 PM(UTC)
kurtrup
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
sorry, model#GST9344EZ0
Simon / APP Team
#4 Posted : Monday, July 16, 2012 4:27:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the drain pump and try without it. Then pull out the motor from the transmission and see if it'll work (you will have to bypass the lid switch).
Check the plug at the motor - jiggle the wires a bit.
Use the video for disassemble instructions
Part number: 285753A
Here are the breakdown diagrams and Replacement parts for Whirlpool GST9344EZ0 DIRECT-DRIVE WASHERS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Dishwasher stops in middle of cycle and has draining problems (Dishwasher Repair)
by Guest 12/21/2022 1:34:11 PM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Frigidaire FTF530 Washer Stops Randomly During Wash Cycle (Dishwasher Repair)
by jensenpe 10/11/2021 7:28:24 AM(UTC)
Bosch dishwasher stops at beginning of cycle (Dishwasher Repair)
by Daniel J 2/23/2021 10:39:24 PM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Washer Stops Spinning Abruptly or Doesn't Spin At All (Washer Repair)
by ggarcia 3/28/2020 9:20:13 AM(UTC)
Maytag dishwasher stops filling then shuts down (Dishwasher Repair)
by fordguy101 11/2/2018 6:58:19 PM(UTC)
Washer stops agitating mid cycle - F7E5 shifter fault (Washer Repair)
by Phil915 9/15/2018 2:45:38 PM(UTC)
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
Washer Stops before pump and spin (Washer Repair)
by tomwing 3/25/2016 1:40:09 PM(UTC)
Maytag washer stops agitating in wash cycle (Washer Repair)
by Teggy87 12/6/2015 8:51:20 AM(UTC)
Washer Stops during Sensing Mode (Washer Repair)
by gotimmygo89 10/5/2015 7:12:57 AM(UTC)
