Model is MAH3000AWW
For a while now when we start a load it will shutoff after a few minutes so we need to press the start button and it will continue. Now it seems as though it doesn't finish. Before, after the spin cycle it would turn the drum for 1-2 minutes then shutoff. Now it just keeps turning the drum and does not stop. If I stop it manually then the door does not unlock. Help please. I did google how to manually unlock but what about solving the problem?
