my oven burner takes a long time to light and when it does it is not burning the hole length of burner. the broiler works good
Groups: APP Team
Hi. If the correct model number is 790.75750103 then you need to replace the oven bake ignitor. If you have the amp meter check the amp draw. Should be 3.25 amp, if less then 3.2 - replace it. The ignitor Part number: 5303935066
Good luck. Post the results. Simon.
oven works great now. thanks
Groups: APP Team
