ramtuf9511
#1 Posted : Tuesday, January 20, 2009 2:32:13 PM(UTC)
ramtuf9511
Our washer will stop in the middle of a cycle.When I unplug it and let it set I hear a click from behind and plug it back in and it starts again. Is it a relay going out? Any help would be appreciated. Thank You
#2 Posted : Wednesday, January 21, 2009 1:38:59 PM(UTC)
Sounds like the motor has gone bad. Remove the washer cabinet and check if the motor is hot when it stops.
Here are the break down diagrams for the Whirlpool washer Model LSQ9659PW2
ramtuf9511
#3 Posted : Thursday, January 22, 2009 6:55:57 AM(UTC)
ramtuf9511
Thanks Gene for replying.I had a load stop again and I tried tapping on the
water level switch and nothing happen,then I push the main control in turned one click and pulled it out and the washer started. What do you think. Thank You
#4 Posted : Thursday, January 22, 2009 11:56:11 AM(UTC)
There is not enough information to make a decision. You have to remove the washer cabinet to check the motor and wires. Also open the control panel and check the wire harness plug at the timer.
papafrita
#5 Posted : Tuesday, March 31, 2009 11:47:50 AM(UTC)
papafrita
How can I fill the oil in the gearcase,what kind of oil and how much do I have to fill?
How can I change the seal in the gearcase?:rolleyes:
#6 Posted : Tuesday, March 31, 2009 12:23:16 PM(UTC)
You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros...ansmission-oil-fill.html
papafrita
#7 Posted : Wednesday, April 1, 2009 5:00:36 PM(UTC)
papafrita
Thanks Gene, I´d like to know if is possible to add oil like 15W40 (for cars) and if is easy the change of the rubber seal. I´m planning to add the oil through this seal, avoiding the removal of all the parts. Do you agree?
Thanks again
#8 Posted : Wednesday, April 1, 2009 5:09:07 PM(UTC)
I would not risk with oil not recommended by the manufacturer. You can add the oil by removing the oil seal (#21 on the diagram).
- The part number for the oil seal is AP3043580
Dishwasher stops in middle of cycle and has draining problems (Dishwasher Repair)
by Guest 12/21/2022 1:34:11 PM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Frigidaire FTF530 Washer Stops Randomly During Wash Cycle (Dishwasher Repair)
by jensenpe 10/11/2021 7:28:24 AM(UTC)
Bosch dishwasher stops at beginning of cycle (Dishwasher Repair)
by Daniel J 2/23/2021 10:39:24 PM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Washer Stops Spinning Abruptly or Doesn't Spin At All (Washer Repair)
by ggarcia 3/28/2020 9:20:13 AM(UTC)
Maytag dishwasher stops filling then shuts down (Dishwasher Repair)
by fordguy101 11/2/2018 6:58:19 PM(UTC)
Washer stops agitating mid cycle - F7E5 shifter fault (Washer Repair)
by Phil915 9/15/2018 2:45:38 PM(UTC)
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
Washer Stops before pump and spin (Washer Repair)
by tomwing 3/25/2016 1:40:09 PM(UTC)
Maytag washer stops agitating in wash cycle (Washer Repair)
by Teggy87 12/6/2015 8:51:20 AM(UTC)
Washer Stops during Sensing Mode (Washer Repair)
by gotimmygo89 10/5/2015 7:12:57 AM(UTC)
