Discuss
Transmission Oil Fill ?
 in
Washer Repair
My Kenmore (made by Whirlpool) direct drive washing machine was leaking from pump so I replaced pump. That fix is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Transmission Oil Fill ?
  #1 (permalink)
Old 01-28-2008, 06:46 AM
Junior Member
DaveSAAB is on a distinguished road
Post Transmission Oil Fill ?
Model Number: 11091554210   Brand: Kenmore   Age: 5 - 10 years
My Kenmore (made by Whirlpool) direct drive washing machine was leaking from pump so I replaced pump. That fix is fine although there are 2 additional problems.
1. To avoid disassembling the case, I disconnected hoses at rear of washer and placed washer on its back on top of 4 wood blocks to gain easy access to pump. Access is easy.
However, oil drained out of the transmission / gear case. I would like to refill the gear case oil. No instructions though.
WHERE DO I REFILL GEAR CASE OIL? I assume the level is low since some did spill out during repair.
2. The old water pump was completely rusted to the motor shaft so what should be a simple removal job was more involved. First I stupidly tried levering pump off the motor shaft which caused some deformation of the front motor bearing/seal. It is slightly noisy but still works - at least for now. I decided to run it as is and see how long it works. Might be years. Or I can replace the motor.
A bit of advice for others doing this job though.
If the pump is frozen (rusted) to the motor shaft - which is very likely if the pump has been leaking around the pump bearing seal since older style pumps have an iron impeller which will rust onto the motor shaft:
- DO NOT TRY TO LEVER PUMP OFF SHAFT - instead:
- remove the motor with the pump still attached. Then force pump off the shaft by placing screwdriver on pump housing and hitting with hammer. Move screwdriver to locations opposite each other to force it fairly straight. This will probably destroy the plastic housing on the old pump (doesn't matter) and it MAY harm motor bearings but there's a good chance you'll get the pump off the shaft with the motor still OK. Worth a try anyway since you'll have to replace pump AND motor if you can't get the pump off and there's no simple way to press the pump off the shaft.
- once the pump is removed from the shaft, clean the shaft up with a flat file. remove all rust and corrosion from the shaft, lightly grease it and the new pump will slide on easily. (note: new pump from APP has plastic impeller which is much less likely to rust onto shaft.)
good instructions for working on Whirlpool direct drive washers available at
RepairAve.com - Free appliance repair help and troubleshooting
Dave
Related Models
Kenmore 11091554210 WASHER
Kenmore 11091564100 WASHER
Kenmore 11091564110 WASHER
Kenmore 11091564800 WASHER
Kenmore 11091564810 WASHER
Kenmore 11091565100 WASHER
Kenmore 11091565110 AUTOMATIC WASHER
Kenmore 11091565200 WASHER
Kenmore 11091565210 AUTOMATIC WASHER
Kenmore 11091565800 WASHER
Kenmore 11091565810 AUTOMATIC WASHER
Kenmore 11091566200 WASHER
Kenmore 11091566210 WASHER
Kenmore 11091566400 WASHER
Kenmore 11091566410 WASHER
Kenmore 11091578100 WASHER
Kenmore 11091578800 WASHER
Kenmore 11091579100 WASHER
Kenmore 11091579800 WASHER
Kenmore 11091587200 WASHER
Kenmore 11091587210 WASHER
Kenmore 11091587400 WASHER
Kenmore 11091587410 WASHER
Kenmore 11092060100 AUTOMATIC WASHER
Kenmore 11092060110 AUTOMATIC WASHER
Kenmore 11092060120 AUTOMATIC WASHER
Kenmore 1109206110 AUTOMATIC WASHER
Kenmore 11092071100 AUTOMATIC WASHER
Kenmore 11092071110 AUTOMATIC WASHER
Kenmore 11092071300 AUTOMATIC WASHER
Kenmore 11092071310 AUTOMATIC WASHER
Kenmore 11092071600 AUTOMATIC WASHER
Kenmore 11092071610 AUTOMATIC WASHER
Kenmore 11092071700 AUTOMATIC WASHER
Kenmore 11092071710 AUTOMATIC WASHER
Kenmore 11092071800 AUTOMATIC WASHER
Kenmore 11092071810 AUTOMATIC WASHER
Kenmore 11092093100 AUTOMATIC WASHER
Kenmore 11092093110 AUTOMATIC WASHER
Kenmore 11092093120 AUTOMATIC WASHER
Kenmore 11092093300 AUTOMATIC WASHER
Kenmore 11092093310 AUTOMATIC WASHER
Kenmore 11092093510 AUTOMATIC WASHER
Kenmore 11092093520 AUTOMATIC WASHER
Kenmore 11092093700 AUTOMATIC WASHER
Kenmore 11092093710 AUTOMATIC WASHER
Kenmore 11092093800 AUTOMATIC WASHER
Kenmore 11092093810 AUTOMATIC WASHER
Kenmore 11092093820 AUTOMATIC WASHER
Kenmore 11092094100 AUTOMATIC WASHER
Kenmore 11092094300 AUTOMATIC WASHER
Kenmore 11092094500 AUTOMATIC WASHER
Kenmore 11092094700 AUTOMATIC WASHER
Kenmore 11092094800 AUTOMATIC WASHER
Kenmore 11092180100 AUTOMATIC WASHER
Kenmore 11092180110 AUTOMATIC WASHER
Kenmore 11092180300 AUTOMATIC WASHER
Kenmore 11092180310 AUTOMATIC WASHER
Kenmore 11092180600 AUTOMATIC WASHER
Kenmore 11092180610 AUTOMATIC WASHER
Kenmore 11092180700 AUTOMATIC WASHER
Kenmore 11092180710 AUTOMATIC WASHER
Kenmore 11092180800 AUTOMATIC WASHER
Kenmore 11092180810 AUTOMATIC WASHER
Kenmore 11092184100 AUTOMATIC WASHER
Kenmore 11092184800 AUTOMATIC WASHER
Kenmore 11092195100 AUTOMATIC WASHER
Kenmore 11092195110 AUTOMATIC WASHER
Kenmore 11092195500 AUTOMATIC WASHER
Kenmore 11092195510 AUTOMATIC WASHER
Kenmore 11092195800 AUTOMATIC WASHER
Kenmore 11092195810 AUTOMATIC WASHER
Kenmore 11092260100 AUTOMATIC WASHER
Kenmore 11092271100 AUTOMATIC WASHER
Kenmore 11092271600 AUTOMATIC WASHER
Kenmore 11092271800 AUTOMATIC WASHER
Kenmore 11092272000 AUTOMATIC WASHER
Kenmore 11092272100 AUTOMATIC WASHER
Kenmore 11092272600 AUTOMATIC WASHER
Kenmore 11092272800 AUTOMATIC WASHER
Kenmore 11092272900 AUTOMATIC WASHER
Kenmore 11092273100 WASHER
Kenmore 11092273600 WASHER
Kenmore 11092273800 WASHER
Kenmore 11092274100 AUTOMATIC WASHER
Kenmore 11092274600 AUTOMATIC WASHER
Kenmore 11092274800 AUTOMATIC WASHER
Kenmore 11092275100 AUTOMATIC WASHER
Kenmore 11092275600 AUTOMATIC WASHER
Kenmore 11092275800 AUTOMATIC WASHER
Kenmore 11092279100 AUTOMATIC WASHER
Kenmore 11092279600 AUTOMATIC WASHER
Kenmore 11092279800 AUTOMATIC WASHER
Kenmore 11092280100 AUTOMATIC WASHER
Kenmore 11092280600 AUTOMATIC WASHER
Kenmore 11092280800 AUTOMATIC WASHER
Kenmore 11092281100 AUTOMATIC WASHER
Kenmore 11092281600 AUTOMATIC WASHER
Kenmore 11092281800 AUTOMATIC WASHER
Kenmore 11092282100 AUTOMATIC WASHER
Kenmore 11092282600 AUTOMATIC WASHER
Kenmore 11092282800 AUTOMATIC WASHER
Kenmore 11092283100 AUTOMATIC WASHER
Kenmore 11092283600 AUTOMATIC WASHER
Kenmore 11092283800 AUTOMATIC WASHER
Kenmore 11092284100 AUTOMATIC WASHER
Kenmore 11092284800 AUTOMATIC WASHER
Kenmore 11092291100 AUTOMATIC WASHER
Kenmore 11092291600 AUTOMATIC WASHER
Kenmore 11092291800 AUTOMATIC WASHER
Kenmore 11092292100 AUTOMATIC WASHER
Kenmore 11092292600 AUTOMATIC WASHER
Kenmore 11092292800 AUTOMATIC WASHER
Kenmore 11092293100 AUTOMATIC WASHER
Kenmore 11092293110 AUTOMATIC WASHER
Kenmore 11092293500 AUTOMATIC WASHER
Kenmore 11092293800 AUTOMATIC WASHER
Kenmore 11092293810 AUTOMATIC WASHER
Kenmore 11092370200 WASHER
Kenmore 11092375100 AUTOMATIC WASHER
  #2 (permalink)
Old 01-28-2008, 02:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dave,
In order to refill gear case oil the gear case has to be removed from the machine.
You have to remove the cover from the gear case. Be careful not to break the seal.
- The part number for the gear case oil is AP3072960
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-04-2008, 12:52 PM
Junior Member
Default
Thanks Gene.
Wondering if instead of disassembling the gear case it would be possible to lever off the old oil seals, dump some oil in and replace the oil seals with new ones?
That seems easier and it also occurred to me that the oil should NOT have leaked out unless the oil seals were bad. (If not the unit should have been pretty well sealed, right? - unless the case were cracked or the gasket between the 2 halves was leaking - neither seems to be the pronlem though)
For now I'm assuming there's still enough oil in the gear case since its not noisy. Realize that's always a dangerous assumption though.
Any advice about e replacing the oil seals and refilling oil at the same time???
  #4 (permalink)
Old 11-27-2008, 09:19 AM
Junior Member
Rivernut is on a distinguished road
Default How to add oil through vent hole
It is pretty easy to add the oil with the transmission out. Any leak should be repaired first, but likely you are reading this because you tipped the washer on its side for a lengthy period of time and the oil leaked out through the vent hole. Here's how to fill it. Remove the transmission first. This requires taking the tub out, and removing the bolts which hold the transmission and motor to the underside of the washer. The transmission slides out through the bottom. You must tip the machine on its side or back to get the long shaft out. Separate the pump,wires and motor from the transmission before sliding it out. The are in with clips which are easy to remove and install. When you get the transmission out, hold it so the shaft is pointing upwards. wipe away any oil which has leaked out through the pin-hole on the top of the case. Sit the transmission on a bench or the ground with something under it to support it so that it sits as straight up as possible. Check the fluid level using a small paperclip. The iol should be no higher than the seam of the case and the lower cast iron section. if you increase the level it will just leak out. Get an all or a large nail and a hammer. Locate the pin-hole (vent) on the top of the case. Put the point of the nail in the hole, and strike it a couple of times with the hammer so as to enlarge the hole and dimple it downwards a little. Get a syringe such as the ones used to refill printer cartridges. The needle fitting is not useful in this next step because it is too small for the gear oil to be squeezed through. Fill the syringe about 3/4 with 80 or 90 weight gear oil commonly used in car rear-ends and manual transmissions (Walmart or Autozone). Position the plastic tip of the syringe into the small dimple you made earlier and push/squeeze the fluid into the hole. Some will leak around the sides, that's okay. Do this until the level is correct. As a finishing touch, I used a rubber plug that came with my computer ink re-filler to plug the hole. It doesn't really plug it as it fits loose, but enough to keep the oil from spilling out during reassembly. You could use a piece of duck tape and pull it off after, or prick a small hole in it for venting. I figured this out as I was replacing a clutch on my Kenmore model 110.229.22101. It should be the same for any washer with a vent hole on the tranny. This saved me from having to remove the top cover which would have ruined the gasket. It is also a neat way of doing it because it avoids the open tranny which could spill.
  #5 (permalink)
Old 11-28-2008, 06:28 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
I have removed a bunch of rusted on pumps and find the best way is spray the motor shaft with WD-40 and carefully pound off the pump, works every time!Just hold the motor and pound away. If a vise is available, probably would help. I tried pounding apart the pump, but they hold up pretty good and is just too much work that way. With the pumps pretty durable, they survive the pounding and the impact drives the pump coupler off the motor shaft. Also, this protects the motor end bell.
__________________
  #6 (permalink)
Old 11-29-2008, 01:32 AM
Senior Expert
APP Volunteer
Default
V2K04 That's real bad advice. The upper nylon gear and pinion depend on oil to prevent overheating. Tranny's get a lot of stress in worst case situations. In any event you provide no evidence this will work without a bunch of oil drained out.
I have taken a lot of tranny's apart and see evidence of heat damage.
__________________
  #7 (permalink)
Old 11-29-2008, 03:31 AM
Senior Expert
APP Volunteer
Default
__________________
  #8 (permalink)
Old 01-04-2009, 02:36 PM
Junior Member
JohnnyK is on a distinguished road
Default
Quote:
Originally Posted by Rivernut View Post
It is pretty easy to add the oil with the transmission out. Check the fluid level using a small paperclip. The iol should be no higher than the seam of the case and the lower cast iron section. if you increase the level it will just leak out.
Any suggestions on how much can leak out and be "OK"?.. I just worked on my in-laws washer and saw the leaking from the vent hole (as it was on it's back) and probably 1-2 oz leaked out before I cleaned it up and taped over it temporarily..
Thoughts?
Thanks in advance.. I'd prefer to not take the tranny out if I can avoid it..
Johnny K
  #9 (permalink)
Old 01-05-2009, 01:37 AM
Senior Expert
APP Volunteer
Default
These tranny's are not cheep, I would fill it with the right oil.
__________________
  #10 (permalink)
Old 01-05-2009, 12:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the oil is AP3072960
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
What transmission oil to use? illfixxit Washer Repair 0 01-15-2010 06:55 PM
no fill for wash but will fill for rinse CSM Dishwasher Repair 3 05-12-2009 12:13 PM
wont fill is it the fill valve acman727 Dishwasher Repair 1 03-14-2009 04:40 PM
Icemaker fill guide and fill tube freezing Cyberheater Refrigerator & Freezer Repair 6 02-05-2009 04:49 PM
Transmission Oil toddpole Washer Repair 1 07-24-2007 10:38 PM
