Ruben Lucero
#1 Posted : Friday, July 27, 2007 5:11:37 PM(UTC)
Ruben Lucero
my oven will not come on I get an F31 code on my control panel the manual recommends changing the RTD Probe which I did I still continue to get the same code after replacing the RTD probe. any suggestions or any advice
Admin / APP Team
#2 Posted : Sunday, July 29, 2007 11:08:41 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Hi Ruben,
Check for shorted RTD harness between EOC (oven control) & Probe connector.
Let us know what you find.
Ruben Lucero
#3 Posted : Sunday, July 29, 2007 6:46:18 PM(UTC)
Ruben Lucero
what is the easiest way to repair or replace the harness how could it short out could i replace the 2 purple wires only? or does the whole harness have to be replaced
Ruben Lucero
#4 Posted : Wednesday, August 1, 2007 2:39:25 PM(UTC)
Ruben Lucero
i checked the probe and the wires i have no short and the probe is good i noticed if i wiggled the probe connecter i sometines lose the reading i tried to use black tape to hold it so does not move it worked but once everything was put back together it still gave me a F-31 code what else could it be thanx
Frigidaire Range FPES3085KFA (Oven Repair (including Ranges and Cooktops))
by walk7078 10/25/2022 3:54:30 PM(UTC)
Frigidaire Range/Stove/Oven: Model FPGF3081KFJ (Oven Repair (including Ranges and Cooktops))
by Guest 8/10/2022 8:26:48 AM(UTC)
Frigidaire Range Control Board Issue (Oven Repair (including Ranges and Cooktops))
by grpuzojr 6/18/2022 4:29:02 PM(UTC)
Frigidaire range burner not working (Oven Repair (including Ranges and Cooktops))
by Hatt65 12/6/2020 11:35:18 AM(UTC)
Frigidaire range backguard removal help (Dishwasher Repair)
by ReginaH 3/1/2020 5:58:25 AM(UTC)
Frigidaire range won't bake (Oven Repair (including Ranges and Cooktops))
by lenjack 6/17/2018 2:25:06 PM(UTC)
Removing Cooktop on a Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by smwilliams 5/12/2015 8:57:01 AM(UTC)
Frigidaire range - No Display (Oven Repair (including Ranges and Cooktops))
by hambob64 1/19/2015 5:59:15 PM(UTC)
Frigidaire range oven problem... (Oven Repair (including Ranges and Cooktops))
by Cr00zng 4/22/2013 7:58:08 AM(UTC)
Frigidaire Range,main Panel. (Oven Repair (including Ranges and Cooktops))
by bthdlm 3/4/2013 9:57:05 AM(UTC)
Frigidaire Range FEF365ASG won't bake or heat oven chamber (Oven Repair (including Ranges and Cooktops))
by lostsole1976 1/7/2013 11:03:19 AM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
Latch Door Motor for Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by hecman 4/17/2012 11:52:02 AM(UTC)
RCI-75-62 Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by keysrose 3/28/2012 1:40:39 PM(UTC)
Frigidaire Range Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by Bruce7799 12/15/2011 5:11:43 PM(UTC)
