Rank:: Member
The frigidaire oven latch door doesn't work. The oven door always open when the oven is working. The motor maybe burned out. What steps needs to be done to replace it?
The oven door must be unlocked during regular cooking. It has to be locked only if you are using self clean.
Rank:: Member
Thanks for your help. Now, what I need to do to avoid the oven door to open when it is cooking something? It is anoying seeing the oven light turning on and off during the cooking process.
