hecman
#1 Posted : 13 years ago
hecman
The frigidaire oven latch door doesn't work. The oven door always open when the oven is working. The motor maybe burned out. What steps needs to be done to replace it?
#2 Posted : 13 years ago
The oven door must be unlocked during regular cooking. It has to be locked only if you are using self clean.
hecman
#3 Posted : 13 years ago
hecman
Thanks for your help. Now, what I need to do to avoid the oven door to open when it is cooking something? It is anoying seeing the oven light turning on and off during the cooking process.
#4 Posted : 13 years ago
You have to check the door hinges, the hinge receptacles and the retainers (#86 & #41 at the diagram).
- The door hinge Part number: 318024747
