lostsole1976
#1 Posted : Monday, January 7, 2013 11:03:19 AM(UTC)
lostsole1976
A year or so ago, the bottom bake element of this oven cracked in two. I replaced the part at that time and it worked fine since.
Now it is back to not baking/heating again in the main chamber. However, this time the bake element did not crack in half and looks fine. So, I'm not sure what to do? Everything else is working fine. Do you think it could be the bake element even though it looks fine, or something else. I don't want to guess if I can avoid it.
Thanks!
Simon / APP Team
#2 Posted : Monday, January 7, 2013 3:41:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the broil doesn't work also, check if the unit getting 240VAC.
If it does - replace the clock/control board
Part number: 316207510
Here are the breakdown diagrams and Backguard parts for Frigidaire FEF365ASG - AppliancePartsPros.com
Post the results.
Simon.
