Hi Everyone,
Sorry this is my first post. My mom just moved into her new apartment which included the fridge provided by the landlord.
The freezer is too warm as the meat is very soft and no sign of any ice in thr freezer at all. A glass of water was also placed inside the freezer and it did not turn into ice at all.
The fridge also is warm too, a bottle of water is slighly below room temperature and so not good at all.
How can we get this fixed or what should I be looking at?
Your responses would be greatly appriciated in advance.
Thanks,
Emil
Here are your parts Replacement parts for Whirlpool ET20NKXFW01 REFRIGERATOR | AppliancePartsPros.comIf the freezer does not work correctly then the frewsh food will also be no good as the fresh food section gets it's cooling from the freezer. You have to do more troubleshooting. Is the compressor running. You can usually hear it and you should also be able to feel it vibrating? Is it cycling on/off or is it on all the time? When the compressor is on does the condenser/compressor fan run? Does the evaporator/freezer fan run? |
THIS FORUM IS DEAD!!!!!!! |
