layman
#1 Posted : Tuesday, June 19, 2012 5:25:18 AM(UTC)
layman
completely stopped working during wash cycle; no activity;not even power button works; reset breaker and unplugged & replugged. door wont open. need to get clothes out and want to know what may have happened.
Simon / APP Team
#2 Posted : Tuesday, June 19, 2012 4:34:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the washer.
To open the door - remove three screws at the rear of the top, slide it 1" back and lift. Locate the door lock on the right, reach to the bottom of it and pull the ring down.
Then find this part - filter emitter and check if it gets 120v to it and through it. Bypass it - it's no longer available.
The filter Part number: 34001330
If the filter is OK - replace the control board
Part number: W10273828
Here are the breakdown diagrams and Replacement parts for Maytag NFW7200TW10 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
layman
#3 Posted : Tuesday, June 19, 2012 10:48:53 PM(UTC)
layman
Simon, need a picture or diagram showing the "three screws at the rear of the top" and the ring. need also a picture / instructions as to where i would find the filter emitter, how to bypass it, and what tool to use to check the emitter. do you know why the emitter is no longer available? replace the control board as in buy a new one or simply put it back where it should be? Thanks Simon.
Simon / APP Team
#4 Posted : Tuesday, June 19, 2012 11:13:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did you open the link with the diagrams and parts breakdown?
Did you pull out the washer and looked at the back?
To check the voltage you need a multimeter. I send you the picture of the filter so when you open the top you will recognize the part.
To bypass means to connect the corresponding wires without the filter.
To find out why the filter is not available you need to contact the Maytag.
Here is the door latch, the ring is at the end, you could find this info at the parts breakdown link if you open it.
The latch Part number: 8182634
Thank you.
layman
#5 Posted : Thursday, June 21, 2012 4:20:42 AM(UTC)
layman
How will the dryer having been installed on top of the washer affect the performance of the repair steps?
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
To check the voltage you need a multimeter. I sand you the picture of the filter so when you open the top you will recognize the part.
Thank you.
Simon / APP Team
#6 Posted : Thursday, June 21, 2012 9:53:14 AM(UTC)
Simon / APP Team
Groups: APP Team
To get to the washer remove the dryer.
Simon.
layman
#7 Posted : Friday, June 22, 2012 7:04:16 PM(UTC)
layman
Simon.
Simon, If I got a pro to come to my home, what would you say would be a resonable price to pay for the repair? Labor and parts included? And would you say that most likely a new control board would be needed?
Simon / APP Team
#8 Posted : Sunday, June 24, 2012 5:50:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You may get the estimate over the phone with several companies. Let the repairman give you the exact opinion on this matter. I already gave you mine. He will have to check the parts and then let you know what is the problem.
Thank you.
Simon.
Guest (5)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
Samsung Washer stopped working (Washer Repair)
by mike613 2/14/2016 9:24:39 PM(UTC)
Crosley Washer Stopped Working (Washer Repair)
by JR2015 6/22/2015 10:23:16 AM(UTC)
Stackable Washer Stopped Working (Washer Repair)
by mbpk0521 10/29/2014 9:07:41 PM(UTC)
Kitchen Aid dishwasher stopped working (Dishwasher Repair)
by acillatem 6/15/2014 6:12:42 PM(UTC)
whirlpool washer stopped working (Washer Repair)
by kenkle 8/24/2013 5:48:22 AM(UTC)
by admiralrepair 7/29/2013 11:17:07 AM(UTC)
washer stopped working in middle of cycle (Washer Repair)
by kmpadilla 6/16/2013 8:09:59 AM(UTC)
Washer stopped working mid cycle ad stopped dryer (Washer Repair)
by AngelaJo81 3/20/2013 9:01:49 AM(UTC)
HotPoint dishwasher stopped working (Dishwasher Repair)
by miklik 8/30/2012 12:18:10 PM(UTC)
Whirlpool Thin Twin washer stopped working (Washer Repair)
by jenjones6775 7/9/2012 7:08:49 PM(UTC)
Frigidaire Front Load Washer stopped working (Washer Repair)
by Kipster28 6/20/2012 2:06:34 PM(UTC)
My Maytag Washer Stopped Working (Washer Repair)
by Susinko 11/3/2011 10:30:47 PM(UTC)
Kenmore washer stopped working, then started again, making really LOUD clanging (Washer Repair)
by cazar1961 9/23/2011 9:24:44 PM(UTC)
Maytag Dishwasher Stopped Working (Dishwasher Repair)
by wdlugitch 7/3/2011 6:53:35 AM(UTC)
