Washer ran through a couple of cycles and stopped without rising. Now when pressing the start/cancel button it clicks but nothing happens. No water, nothing.
Check your water supply hoses by detaching them from the wall and seeing if you have water coming to the unit. Check the inlet screens between the hose and the rear of the unit, it may be clogged. Then put back together and see if you have voltage to the inlet valve when you try and turn the unit on to flll. Should have 120v to inlet and if you don't you may have a problem with your timer or main board.
