Originally Posted by: Gene
I did not give up on you but I need you to follow my instructions. I'm attaching these files again.
Pre-diagnostic Check:
Compressor sound like it cycles off and on.
Condenser fan motor runs fast, slows down, high pitched tone, (click, click)and then starts up again and repeats the sequence.
Could not recognize Motorized Air Door. There is a plastic attachment that had some cool air coming from freezer side that had a similar unit at the same spot, just the otherside of the wall.
Refrigerator Thermistor: It's attached, no buttons or scres, or area for a read out.
Evaporator Fan Motor: Cycles on and off. Lower part of freezer is frosted over with frozen snow.
Operate the Evaporator fan at 3000 rpm...How ? I didn't see any place to
set it and same for Condenser fan motor and compressor
Diagnosis / Troubleshooting per the instructions
Top row of numbers do not stay on just flash.
Freezer shows 3, Refrigerator shows 34, Water Filter show 99
Enter diagnostic mode: no beep, keeps flashing, no read outs that correspond to diagnostics chart.
WFI test, did not due as we had water leak some time ago so we just turned off the water source and went without Ice Maker and Water dispenser, due to no $$"s for a repair bill.
Reply #2___________________________________________________________________
My e-mail said you sent a msg and I went and followed the directions. But when I cam back to give you my results I saw you actually sent the msg to Wendy. So since I did what you told her to here are my results. Turned the power off so I would get shocked. Got the back off in the Freezer. Coils had Ice on the, and the water drain was frozen over. Took a high powered LED light and check under the Freezer and it was dry. What do I do next ?
6/13/2012 @ 9:50pm ET / Checked the Freezer and all is dry and drain has defrosted. I'm feeling pretty good about it, almost finished ?
What's next ? Thanks !
6/14/2012 @ 8:00am.............Update.
I turned my frig/freezer back on to see if it was fixed. Nope ! This morning, checked it out, and the coils were icing up again. Little plastic fan was running. Freezer was cold, and Frig was slightly cool. Readings were Freezer 3, Frig 34, Water 99. It has a steady beep-beep going on now ? Where do I go now Gene ? Thanks !
