I have a whirlpool refridgerator model ED2FHAXSB03 and I am having problems with the defrost system, it keeps frosting up causing the fridge to be too warm. The defrost heater has resistance and I have already changed the defrost thermostat, but I am still having problems. Is there a way to know if my control board is bad, or is there something else I should be looking at?
Was thanked: 10 time(s) in 10 post(s)
THIS FORUM IS DEAD!!!!!!! |
I tried both ways on the tech sheet to force a defrost and could not get either way to work. The tech sheet says I should be hearing a relay click, but I did not. Where do I go from here?
You could check the wiring for continuity with a meter.
Since you cannot hear the relay click I would say that the defrost control board is shot. Also by the process of elimination this is all that is left. |
