allemich
#1 Posted : Sunday, April 19, 2009 8:02:07 PM(UTC)
allemich
I have a whirlpool refridgerator model ED2FHAXSB03 and I am having problems with the defrost system, it keeps frosting up causing the fridge to be too warm. The defrost heater has resistance and I have already changed the defrost thermostat, but I am still having problems. Is there a way to know if my control board is bad, or is there something else I should be looking at?
#2 Posted : Monday, April 20, 2009 1:27:28 AM(UTC)
Replacement parts for WHIRLPOOL ED2FHAXSB03 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...heet%20-%20W10142176.pdf
It shows how to force a defrost.
If a forced defrost works then the defrost control board is shot.
allemich
#3 Posted : Monday, April 20, 2009 8:33:55 AM(UTC)
allemich
I tried both ways on the tech sheet to force a defrost and could not get either way to work. The tech sheet says I should be hearing a relay click, but I did not. Where do I go from here?
#4 Posted : Monday, April 20, 2009 6:08:30 PM(UTC)
You could check the wiring for continuity with a meter.
Since you cannot hear the relay click I would say that the defrost control board is shot. Also by the process of elimination this is all that is left.
Guest (5)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by Gene 1/8/2008 6:46:15 PM(UTC)
