Welcome Guest! To enable all features please Login or Registers.
allemich
#1 Posted : Sunday, April 19, 2009 8:02:07 PM(UTC)
allemich
I have a whirlpool refridgerator model ED2FHAXSB03 and I am having problems with the defrost system, it keeps frosting up causing the fridge to be too warm. The defrost heater has resistance and I have already changed the defrost thermostat, but I am still having problems. Is there a way to know if my control board is bad, or is there something else I should be looking at?
#2 Posted : Monday, April 20, 2009 1:27:28 AM(UTC)
Was thanked: 10 time(s) in 10 post(s)
Replacement parts for WHIRLPOOL ED2FHAXSB03 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...heet%20-%20W10142176.pdf
It shows how to force a defrost.
If a forced defrost works then the defrost control board is shot.
allemich
#3 Posted : Monday, April 20, 2009 8:33:55 AM(UTC)
allemich
I tried both ways on the tech sheet to force a defrost and could not get either way to work. The tech sheet says I should be hearing a relay click, but I did not. Where do I go from here?
#4 Posted : Monday, April 20, 2009 6:08:30 PM(UTC)
You could check the wiring for continuity with a meter.
Since you cannot hear the relay click I would say that the defrost control board is shot. Also by the process of elimination this is all that is left.
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by Gene 1/8/2008 6:46:15 PM(UTC)
